For all of you new guys that want to go fast!
Old 04-14-2015, 01:56 PM
  #76
jmb614's Avatar
E55 AMG
Hammer, you mentioned earlier in the thread that anything above ~172 crank pulley needs an 82mm TB. Why is that?
I've seen it mentioned before that stock TB's are good for up to 600HP, thus I've never bothered, especially considering the 'hiccup' issues others have spoke of. I still tend to believe that cooling is the biggest problem.
Old 04-14-2015, 02:10 PM
  #77
Hulk's Avatar
A Merc
600hp with a stock tb, never seen that
Old 04-14-2015, 02:33 PM
  #78
Hammer Down's Avatar
2015 E63S, 2018 E63S
anything bigger than a 175mm i would go with an 82mm. the more air that you can force in the engine the more power you can make
Old 04-18-2015, 05:44 PM
  #79
Originally Posted by Hammer Down
Lately I've read various post about what to do and which mods should I get. I listed a few different members mods that are tried and true so some of you can stop trying to reinvent the wheel. All of the mods below contain the same go fast parts. Take from it what you want but one things for sure.....you will go faster! Mods should make this a sticky. If I left some guys out I'm sorry but it takes some time to do this from an IPad.
Lowprofile's Mod list:
Engine-
TTM 82mm t/b
TTM Modified i/c
TTM Fuel rail and injectors
OETuning street and race tune with flash loader
4 gallon reservoir tank w/ bosch pumps
Modified h/e
ASP 185mm pulley, modified stock pulley with lightweight aluminum outer ring
ASP aluminum w/p pulley
Exhaust-
MBH headers
Cat-less mid pipes -> x-pipe -> stock resonator -> stock mufflers
Trans-
All stock including tcu
Rear-
Quaife differential
Fuel-
VP MS109
Hammer Downs Mod list:
OE Tune for 91
MBH Headers (stock secondary cats, stock resonator and stock mufflers)
ASP 185mm Pulley
ASP Misc Pulley's
TTM Fuel Rail & Injectors
Original TTM 82mm TB
Custom CAI Intake
Phenolic Spacers
EC Heat Exchanger
DADS Rear Tank w/ Rule Bilge Pump
Meziere WP136
160 T-Stat
One Step Colder NGK Plugs
DEI Spark Plug Heat Shields
DEI Intake Tube Wrap
JEGS Heat Barrier Wrap for CAI
Chevron 91 mixed with ERC's 100..50/50 mix
E55Rockets Mod List:
Eurocharged dyno tune/TCU tune
195mm pulley
DPF 82mm throttle body/ported 80mm plenum
DPF ported heads
PTE cams
Stock rail w/550cc injectors
Ported surge tanks and s/c runners
Dad trunk tank w/meizier
DPF custom intake
DPF 3" exhaust
Kleemann headers
Quaife diff
Loungn14's Mod List:
EC long tube headers w/ 3in. piping, no resonators, stock mufflers
EC 185 pulley w/ ASP idler pulleys
EC 82 throttle body (ground down)
EC heat exchanger w/ Mezziere pump wired to key
EC red 550cc injectors and TTM looped rail
EC TCU tune
EC 93oct dyno tune for street
EC Race gas dyno tune for racing
Carbonio carbon fiber air box
Carbonio carbon fiber intake tubes
TTM intake scoops
1 step colder plugs
3gal trunk tank w/ Rule2000 intank pump wired to key
RedBullJnky's Mod List:
EC long tube headers w/ 3in. piping, MagnaFlow X-pipe, and NO cats, res, or mufflers
EC 82 throttle body
EC red 550cc injectors and NO looped rail
EC TCU tune
EC Q16 dyno tune for racing
Carbino carbon fiber air box
Carbino carbon fiber intake tubes
Quaiffe LSD
TTM intake scoops
1 step colder plugs
Cobra HE mounted under the trunk
3.5gal trunk tank w/ Rule2000 intank pump wired to key
1.5gal AEM water/meth injection
CHawkins Mod List:
Tuned by Tony Lawshee @ BIP
BIP 82mm Throttle Body
BIP Heat Exchanger with nitrous ring
BIP Trunk Tank
BIP Meth Kit
BIP intercooler
Floored Fab Longtubes
BIP electric cut outs off the headers w/ offroad x pipe
Wavetrac LSD
BIP E85 Conversion
340lph dual fuel pumps
BIP Red 1000CC Injectors with TTM looped rail
TTM scoops
TTM 188MM Pulley made by ASP
Bump so that you don't have to search for the mods since I started a part II to this thread.
Old 06-12-2015, 02:02 PM
  #80
WiscoSean's Avatar
1998 Chevy Astro, 2003 Mercedes E55
It seems that something is wrong with my car if these cars are running such high mph in the 1/4
My mods are as follows
Evosport Shortie Headers with primaries deleted
Stock secondary cats, Stock resonator, Stock Mufflers
175MM Crank
Eurocharged Beltwrap Kit
Split Cooling
82MM MB Throttle Body
Intake Scoops
K&N Filters
Car dynoed at 480whp/590ftlb on a dynojet
I ran a 11.44@123.01 on probably the best DA I could get. It was last November in Wisconsin with low humidity probably 50degrees
I was thinking of putting an x pipe, killer chiller, trunk tank and meth in but i just cant see getting 6mph in the 1/4 with these mods. When I ran the car at 80degrees and mild humidity my best mph was 121 and went down to 117 after back to back to back pulls. Some of you guys say you are running 128mph in 80 degrees.
Old 06-12-2015, 02:29 PM
  #81
2000UZJ's Avatar
E55
175MM Crank
Split Cooling
Intake Scoops
K&N Filters
I am sure you forgot to type upgraded heat exchanger and IC Pump?
Old 06-12-2015, 03:04 PM
  #82
WiscoSean's Avatar
Yes my bad, has an upgraded IC Pump and H/E. It also has a Speedriven Tune
Old 06-12-2015, 03:12 PM
  #83
e55amgrocket's Avatar
Dirt Scooters
175MM Crank
Split Cooling
Intake Scoops
K&N Filters
I went anywhere from 130-133mph when it was 82 degrees outside. My IAT would be right around 34-35 degrees at the start of a run and usually no more than 110 by the end of a run. IAT's are HUGE with these cars
Old 06-12-2015, 08:25 PM
  #84
RedBullJnky's Avatar
you to Hate
Agreed!!!!
Additional cooling is a must on these cars. Just a HE and pump is not enough for a stage 3.
Old 06-13-2015, 06:56 PM
  #85
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
great resource.....
I have 185mm ASP pulley
PLM HE
Pierburg IC with custom harness
s/c pulley protector kit
Shardul Belt wrap kit
eurocharged headers
82mm TB with ported snout
sitting here waiting to go on... I need a set of injectors and a tune and Im good to go.
Old 07-20-2015, 09:41 PM
  #86
Ruthle55's Avatar
e55 amg
Is there any specific reason no one in this last has just simply upgraded the super charger pulley with a smaller pulley vs swapping out the crank pulley?
Old 07-20-2015, 11:04 PM
  #87
you to Hate
The smaller sc pulleys weren't around when we did those runs.
Old 07-22-2015, 02:43 PM
  #88
blackbenzz's Avatar
haters crazy
Do a search on sc pulleys reliability
Old 07-22-2015, 02:59 PM
  #89
Rob CL's Avatar
E55 AMG | Buell Lightning XB12
Have the grenades been spread around the total production run, or were they isolated to the earlier units? I have one awaiting installation, but I'm on the fence as to whether I should pick up a scatter shield before I go down that road.
Old 07-22-2015, 03:02 PM
  #90
2000UZJ's Avatar
E55
A scattershield would be a good investment...
Old 07-22-2015, 03:06 PM
  #91
Rob CL's Avatar
I agree... Was that lm7 that was making them? I believe I've bought from him in the past.
Old 07-22-2015, 03:19 PM
  #92
2000UZJ's Avatar
E55
I have one on a stock pulley. Great insurance.
latemodel21 makes them.
Old 07-22-2015, 04:08 PM
  #93
Rob CL's Avatar
Yes. That's him. Thanks man!
Old 12-08-2015, 07:04 AM
  #94
sexyxe's Avatar
04 E55
Took me 24 pages but I found it!
Just wanted to bump it, as I'm about to buy some headers, cats, retune and see what should be my next step from there.
Old 04-11-2016, 02:57 AM
  #95
Ruthle55's Avatar
e55 amg
Some guys also need to realize some of those higher mph runs and times are NOT on straight 91-93. Race gas and a good tune alone Id guess is worth 4-5mph on its own.
Old 04-11-2016, 07:43 AM
  #96
sexyxe's Avatar
04 E55
Good thread mine. Just bought a trunk tank, Snow stage 2 meth kit and 82mm TB. Would be nice to get it in for the start of the drag season here.
Quick Reply: For all of you new guys that want to go fast!
