For all of you new guys that want to go fast!
Lately I've read various post about what to do and which mods should I get. I listed a few different members mods that are tried and true so some of you can stop trying to reinvent the wheel. All of the mods below contain the same go fast parts. Take from it what you want but one things for sure.....you will go faster! Mods should make this a sticky. If I left some guys out I'm sorry but it takes some time to do this from an IPad.
Lowprofile's Mod list:
Engine-
TTM 82mm t/b
TTM Modified i/c
TTM Fuel rail and injectors
OETuning street and race tune with flash loader
4 gallon reservoir tank w/ bosch pumps
Modified h/e
ASP 185mm pulley, modified stock pulley with lightweight aluminum outer ring
ASP aluminum w/p pulley
Exhaust-
MBH headers
Cat-less mid pipes -> x-pipe -> stock resonator -> stock mufflers
Trans-
All stock including tcu
Rear-
Quaife differential
Fuel-
VP MS109
Hammer Downs Mod list:
OE Tune for 91
MBH Headers (stock secondary cats, stock resonator and stock mufflers)
ASP 185mm Pulley
ASP Misc Pulley's
TTM Fuel Rail & Injectors
Original TTM 82mm TB
Custom CAI Intake
Phenolic Spacers
EC Heat Exchanger
DADS Rear Tank w/ Rule Bilge Pump
Meziere WP136
160 T-Stat
One Step Colder NGK Plugs
DEI Spark Plug Heat Shields
DEI Intake Tube Wrap
JEGS Heat Barrier Wrap for CAI
Chevron 91 mixed with ERC's 100..50/50 mix
E55Rockets Mod List:
Eurocharged dyno tune/TCU tune
195mm pulley
DPF 82mm throttle body/ported 80mm plenum
DPF ported heads
PTE cams
Stock rail w/550cc injectors
Ported surge tanks and s/c runners
Dad trunk tank w/meizier
DPF custom intake
DPF 3" exhaust
Kleemann headers
Quaife diff
Loungn14's Mod List:
EC long tube headers w/ 3in. piping, no resonators, stock mufflers
EC 185 pulley w/ ASP idler pulleys
EC 82 throttle body (ground down)
EC heat exchanger w/ Mezziere pump wired to key
EC red 550cc injectors and TTM looped rail
EC TCU tune
EC 93oct dyno tune for street
EC Race gas dyno tune for racing
Carbonio carbon fiber air box
Carbonio carbon fiber intake tubes
TTM intake scoops
1 step colder plugs
3gal trunk tank w/ Rule2000 intank pump wired to key
RedBullJnky's Mod List:
EC long tube headers w/ 3in. piping, MagnaFlow X-pipe, and NO cats, res, or mufflers
EC 82 throttle body
EC red 550cc injectors and NO looped rail
EC TCU tune
EC Q16 dyno tune for racing
Carbino carbon fiber air box
Carbino carbon fiber intake tubes
Quaiffe LSD
TTM intake scoops
1 step colder plugs
Cobra HE mounted under the trunk
3.5gal trunk tank w/ Rule2000 intank pump wired to key
1.5gal AEM water/meth injection
CHawkins Mod List:
Tuned by Tony Lawshee @ BIP
BIP 82mm Throttle Body
BIP Heat Exchanger with nitrous ring
BIP Trunk Tank
BIP Meth Kit
BIP intercooler
Floored Fab Longtubes
BIP electric cut outs off the headers w/ offroad x pipe
Wavetrac LSD
BIP E85 Conversion
340lph dual fuel pumps
BIP Red 1000CC Injectors with TTM looped rail
TTM scoops
TTM 188MM Pulley made by ASP
Engine-
TTM 82mm t/b
TTM Modified i/c
Modified h/e
Exhaust-
MBH headers
Trans-
Rear-
Quaife differential
Fuel-
VP MS109
OE Tune for 91
ASP 185mm Pulley
ASP Misc Pulley's
Custom CAI Intake
Phenolic Spacers
EC Heat Exchanger
Meziere WP136
160 T-Stat
195mm pulley
DPF ported heads
PTE cams
DPF custom intake
DPF 3" exhaust
Kleemann headers
Quaife diff
EC TCU tune
TTM intake scoops
1 step colder plugs
EC 82 throttle body
EC TCU tune
Quaiffe LSD
TTM intake scoops
1 step colder plugs
CHawkins Mod List:
BIP Trunk Tank
BIP Meth Kit
BIP intercooler
Wavetrac LSD
BIP E85 Conversion
TTM scoops
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
If I ran mine on the track sure I would hit 10a but I dont. But I do know mine is damn quick with my mods. All of which you listed are in some way on each car you listed.
This is what I'm talking about follow the list and you will fly. I don't have Alan's Bassn07's list or I would've posted it. I duplicated his setup with the only difference being that he had Floor Fabbed Headers, Remntech's Carbon fiber intake and a ASP 180mm crankshaft pulley. I believe the parts from Alan's car are also on the list from above and yes he ran 10.7
How about just "sort of" fast.
I've already got MBH LT's and the Quiafe.
I was going to do PLM H.E., ASP 174mm pulley, and a tune.
Is that safe enough without having to get into injectors, bigger coolant tanks, fuel rails, etc...
Thanks!
Thanks!
If I were you I would go EC heat exchanger, separate the cooling and go with the tank that fits where the air cabin filter sits and top it off with any pulley between 168-172 (anything bigger and you will have to upgrade your tb to 82mm)with a really good tune (road tune preferred) and call it a day.
Seems like 650 HP is the limit for bolt ons with stock supercharger.
Until someone releases some aggressive cams and or adjustable cam gears, that would be nice.
Yea, not exactly what we would normally call a bolt on. But, yea it bolts on right LoL ;-) . Without a bigger set of cams, higher flow numbers will help a little but. you won't get the big results until you increase lift and duration of your valves.
Dirt Scooters
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
all right. I have no idea what I am doing but here is what I have done so far. any pointers would be appreciated:
1. installed the belt wrap kit
2. installing the PLM Heat Exchanger
3. Installing the Bosch 010 pump
4. installed the hurricane scoops
What next? should I upgrade the SC pulley next? or should I do 82MM TB and upgrade the CAI?
Thanks guys - this is fun.
I'm still lurking
. The best dyno I had was 619rwhp but found out my intake was killing me on the track so I ran it with no filters. I think that was good for another 20 on the dyno. The car is sitting in the garage with no motor still. Business blew up in 2013 and we just finished building a house so I was pretty busy. Chris (Sir-Boost-A-lot) has the engine. Guess Ill send him a text and finally get the ball rolling again
. I bought a new Shelby to keep me going until then. Haven't took it to the track yet but pretty sure I'll run well into the 10's the first time out and in the 9's after that. They're so easy to go fast.
