Did oil change on my E55 now its smoking like a mutha !
Did I miss something ?
I checked oil level with the dipstick and it is perfect, also the dash says level is good.
Mainly it is on idle, driving not so bad.
Maybe the previous owner had special oil in it ? over the last 6000 miles I have had to add 3 quarts to it and it never smoked ??
I wouldn't have though an oil change is that complicated ?
Did oil filter as well, K & N
running around 14 pounds boost.( not stock )
oil consumption doesn't bother me that much, but this new smoke does !
Maybe the previous owner had some magic no smoke oil in it ?
only other thing was when I put the oil in the motor I poured it in through the oil filter opening, didn't think it would matter ?
At any rate are you sure you completely drained before adding new oil? Keep in mind there are 2 drain plugs that require removal. If you're sure it was drained correctly then it should have needed about 8.5 liters replaced.
however I checked the level with the dipstick,and was actually a bit low, same with the electronic reading also a bit low.
as i went in a bit low and then topped it up, it is now perfect level and still does it i think.
may drain it all tomorrow and go 0-40 oil
Truth is you may have broken piston lands, time for a compression test and or leak down test. The M113K should go 12,000 miles with less than quart of oil burn off.
Sorry to say you (previous owner) may have had (put) magic oil in that engine for the last 6000 miles.
ok yes it used some oil, but didn't blow smoke.
only after the oil change, did this happen.
The previous owner may have had magic oil in it, but I doubt it, as I had topped it up 3 times and it never puffed any.
Only after I put MY magic oil in it , did this happen !
Tomorrow I will drain it from both plugs and put new 0-40 full synthetic in it, wish me luck !
Why would you not just put in what the owner's manual calls for and be done with it? If you overfilled the motor, that could be causing your smoking.
So I don't see how it is over full. instead of just adding an amount that the internet tells me I actually check it.
What makes you think that? Because it says K&N?
I let the car sit for 10 minutes engine off to check the level.
Also the smoke was when it was low, 150mm on the dipstick.
However I replaced the oil anyway with 5/40 and no additives and is now fine.
No wonder these cost so much to service you gotta change the oil twice !!
Thanks for all your help.
