Any chance of fitting 20x9.5 wheels on the front?
Old May 16, 2015 | 11:58 AM
justinreinke's Avatar
04 E55, 91 560sel
I did search quite a bit and I know most run 8.5 or 9 inch wide wheels up front. It seems around 35mm offset is about right and then some actually run spacers. I was looking at a set of wheels that are staggered 20x9.5 and 20x10.5 et42 all around. The backs seem about perfect but the front is questionable. I think the will fit fine on the outside but maybe not the inside? Are we just talking about losing a bit of turning radius or is it more serious? Probably looking at a 255 tire. Need a little help from people that run a bit more aggressive wheel sizes. I do no want to bend the front fenders up after the first dip, pothole or speed bump.
Maybe I should keep looking for 19's but I think I can get a decent deal.
Old May 16, 2015 | 12:18 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You may have to grind the ball joint end on the upper wish bone to clear the tire
Old May 16, 2015 | 04:01 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
FWIW I'm running 20*10 et27 (245/30/20) all around on my wagon. I do have to drive very carefully when low, though.
Originally the wheels were et37 and I added 10mm spacers. It fight fine originally, as well.
Any chance of fitting 20x9.5 wheels on the front?-4bbe5cb3-cc1e-4a2f-9761-004a7351bf0e.jpg
Old May 16, 2015 | 05:34 PM
04 E55, 91 560sel
Do you mean I just need to grind the threads down on the upper ball joint or is there more to it? Any adverse affecs to doing this? I doubt it, usually pretty difficult to remove ball joints when you want to. Any issues with the steering knuckle itself?
That wagon is sweet!!! I am not looking to go anywhere that low. But if you were running 10's et37 that should be within a mm or 2 of 9.5 et42. Sounds promising. Did you need to do much to get them to fit? 245s would give more stretch but I am hoping to get as much wheel protection as possible.
Love the cl with the Kleemann's. The wheels I am looking at are Kleemann ts-6. My car was owned by Kleemann who used the car for mapping ecu's and is local to me so I figured they would be a pretty nice tribute to the car. Not the easiest wheels to find used.
Old May 16, 2015 | 09:01 PM
OCKlasse's Avatar
MBworld Guru
I have done no fender mods
The TS-6 is one of my favoirte all-time wheels. I hope they work for you if not PM me
Old May 17, 2015 | 05:01 PM
Panzer55's Avatar
E55 AMG 2006
I have 9,5x20" ET 15 front with 285/25 and 10,5x20 rear with 305/25. Never rubbed,,even when airmatic in lowest mode
Old May 17, 2015 | 05:22 PM
Justiso's Avatar
2003 E55
ET15 is that correct? Or was wrong button pushed
Old May 18, 2015 | 01:26 PM
Panzer55's Avatar
E55 AMG 2006
yes correct,,I will try to post the pic I took
Old May 18, 2015 | 01:43 PM
Panzer55's Avatar
E55 AMG 2006
its a bit blurry,,but I give you my word it says 9,5x20,,,and ET 15 is better visible
Attached Thumbnails Any chance of fitting 20x9.5 wheels on the front?-20150505_160909.jpg   Any chance of fitting 20x9.5 wheels on the front?-20150505_160913.jpg
Old May 18, 2015 | 06:23 PM
Justiso's Avatar
2003 E55
That aggresive ET make me believe they are made for CLS model.
It's not going to work.
I have seen AMG wheels with ET28 9.5" in front of E55 and thats very near limit.
Old Jun 15, 2016 | 12:03 PM
MUSTANGRIDAH's Avatar
04 E55/04 SL55/R35 GTR
Any pics of this??
