some new goodies for my first project arrived today!
Subscribe
Jun 11, 2015 | 05:44 PM
Finally got all the necessary tools and parts to work on the beast. Doing spark plugs, wires, and valve cover seals. I believe I will still need some rtv for the seals. I am a bit disappointed at how the valve cover gaskets were packed. Hopefully it won't cause any problems. Is there anything else I need to tackle this project?
This wrench feels great excellent craftsmanship.
Reply 0
Jun 11, 2015 | 06:17 PM
A 17mm open end wrench to pop the leads off the spark plugs
On the rocker covers you will need RTV silicone for the breather top and the oil filler top (photo attached so you know what I mean)
None needed on the main seals
Reply 0
Jun 11, 2015 | 06:20 PM
Gotcha. thanks for the heads up. I bought the spark plug removal tool and forgot to take a picture. Are you sure no rtv for the main seal?
Reply 0
Jun 11, 2015 | 06:22 PM
Quote: Gotcha. thanks for the heads up. I bought the spark plug removal tool and forgot to take a picture. Are you sure no rtv for the main seal?
It's not recommended in the manual, I didn't need to use any on mine and they are fine, no leaks
Just make sure you clean out the valley for the gasket really good on the covers
Reply 0
Jun 11, 2015 | 06:38 PM
Quote: It's not recommended in the manual, I didn't need to use any on mine and they are fine, no leaks
Great! Will do. Thanks for the help!
Reply 0
Jun 11, 2015 | 06:40 PM
Quote: Great! Will do. Thanks for the help!
Just one last thing
After you fit everything back up and take it for a drive, after it cools back down check the torque settings again
You don't HAVE to do this but is something I do to triple check everything is good
Reply 0
Jun 11, 2015 | 07:22 PM
Makes sense. I will wait 24 hours for the RTV to cure then take her for a spin!
Reply 0
Jun 11, 2015 | 07:41 PM
it was a pita cleaning up those valve covers.. but it ran way better... worth the time if you like diy...
good job!
Reply 0
Explore
Jun 11, 2015 | 07:46 PM
Quote: it was a pita cleaning up those valve covers.. but it ran way better... worth the time if you like diy...
good job!
Already bought some brake cleaner and metal polish! Going to be a fun project
Reply 0
Jun 11, 2015 | 07:54 PM
You need an in-lbs torque wrench for the valve cover bolts. The spec is 72 in-lbs.
Reply 0
Jun 11, 2015 | 08:24 PM
Quote: You need an in-lbs torque wrench for the valve cover bolts. The spec is 72 in-lbs.
Already bought a sexy one from precision instruments
Reply 0
Jun 11, 2015 | 08:26 PM
I'm using red rtv for temperature up to 650F. Has anyone had experience using the higher temperature black rtv or will the red work?
Reply 0
Jun 12, 2015 | 12:06 AM
In-lbs is nothing; 6 ft-lbs. Just gently snug by hand and be done.
Reply 0
Jun 12, 2015 | 01:09 AM
Quote: In-lbs is nothing; 6 ft-lbs. Just gently snug by hand and be done.
Thanks will do!
Reply 0
Subscribe
Currently Active Users (1)
