Gutted factory resonator
Old Aug 30, 2015 | 03:02 PM
romeomikehotel's Avatar
cls55 amg
Hey guys, I want to share some info that you may or may not find useful but hopefully someone benefits from at some point
I was planning on cutting out the center resonator and welding in straight pipes over the weekend but curiosity got the best of me after I came across some threads about gutting the factory mufflers. I decided after finding nothing but speculation to find out what was inside the stock resonator. Unsurprisingly it is very similar to the stock mufflers in terms of the sound deadening material. What is interesting is that the tubing running through it is almost identical in size to the rest of the exhaust, the only difference being the perforations in the tube like what is found in the mufflers.
After my investigation I yanked out as much sound deadening as possible and welded the resonator back together. The results are pretty much as expected... Not much difference in sound other than more noise on the overrun when decelerating. I did this with the plan to run straight pipes if it didn't turn out like I wanted but between removing the sound deadening from the mufflers and the resonator I'll probably leave the exhaust alone for a while with the exception of some headers in the future.
One way this may help some of you who are planning to remove the whole resonator is to instead cut away all of the resonator housing and then have an exhaust shop replace just the 5 inches or so of perforated tube on each side... This should lower the cost significantly if you cut away the housing yourself.
Old Aug 31, 2015 | 09:48 AM
Toadster's Avatar
2005 E55 AMG
removing my resonator and replacing with straight pipes was $60
Old Aug 31, 2015 | 10:53 AM
Elhonaz's Avatar
W211 E55 2003
Leaving everything else stock, will the resonator delete cause drone? Hows the sound?
Old Aug 31, 2015 | 11:56 AM
WideLowandFast's Avatar
I had my resonator removed (E63). No drone and amazing sound out the back!
Old Aug 31, 2015 | 12:12 PM
tumbler510's Avatar
2009 Nissan Frontier PRO-4X. SOLD: Stage 3 B5 S4
I feel like if you are planning on selling the car in the future, you'd want to hang onto the resonators for reinstall later. If you gut them and modify them, it'll be 10x harder to get back to OEM. Just my 2cents.
Old Aug 31, 2015 | 06:00 PM
cls55 amg
Yea I agree its not expensive to have done, I may still have mine replaced. I just wanted to see what was inside because all that was online was speculation... this was just a weekend experiment.
Like I said, this probably isnt going to matter to many people but I had some time on the weekend to mess around and this is what I found. And to whoever asked, no drone at all. The car sounds stock from inside. I'll try and get a video up later on.
This is also true. I'm in a different position than most though as I dont plan on selling my cls, most likely just retiring it in a year or so when I buy another car so I have less concern than most with modifications.
Old Aug 31, 2015 | 06:30 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Thanks for posting the pix. Any info is good info. I just wish someone would cut open a c63 muffler. Someone somewhere must have a smashed one we can cut open
Old Aug 31, 2015 | 06:50 PM
Toadster's Avatar
2005 E55 AMG
no drone
Old Sep 1, 2015 | 03:07 PM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
Delete resonator does not gain power but actually lose hp. It just made it sound louder. This is what my buddy said and he's mb master tech. Best way is to replace the exhaust system.
Old Sep 1, 2015 | 04:23 PM
Elhonaz's Avatar
W211 E55 2003
replacing the resonator with a x pipe should not lose any hp.. isnt the the factory resonator a "xpipe" inside?
Old Sep 1, 2015 | 07:21 PM
cls55 amg
no. read first post/look at pictures in first post.
Resonator delete will not increase or decrease horsepower. Just noise
