How do I eliminate the 18psi limp mode with my 180/77
Old Sep 21, 2015 | 01:30 AM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
My car will hit limp mode as soon as I hit 18psi of boost and then I have to turn the car off and restart it otherwise the car will just bog down anything over 3k rpm. I have all cooling and exhaust mods necessary. Will a tune disable or raise the limp mode to at least 20psi? What are you guys doing whoever has this same setup? Or do I switch back to a 180/83 setup?
Old Sep 21, 2015 | 02:00 AM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
https://splitsec.com/
Welcome to the next level of frustrations. Map Clamp it and call it a day......
Old Sep 21, 2015 | 02:20 AM
what do I buy from there? What does that do?
Old Sep 21, 2015 | 02:52 AM
Rob CL's Avatar
E55 AMG | Buell Lightning XB12
It basically remaps your input at the sensor.
In "lay" terms:
Say a wealthy investor tells his "nanny" that he's measured at nine inches. This is all well and good, per se.
---Except, he's measuring from the exhaust, to the tip, so-to-speak. At the end of the night, the "nanny" sees six inches, even though he's really carrying the "extra three".
This is how devices such as these can help this situation, if you follow the euphemism.
Be advised, you will have to re-scale your ECU, to make everything play nice (since your ECU is really only programmed to see X amount of pressure).
Hope that helps.
Old Sep 21, 2015 | 08:27 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
In "lay" terms:
Hope that helps.
That explanation while is beautifully accurate.
Old Sep 21, 2015 | 09:20 AM
jmb614's Avatar
E55 AMG
In "lay" terms:
Hope that helps.
Certainly are pushing the threshold of the superchargers efficiency.
Old Sep 21, 2015 | 10:20 AM
EREBUS's Avatar
This......
https://splitsec.com/product/vc3-100-voltage-clamp/
You splice into to the map sensor cable and set the voltage to @4.5v......ish. ECU goes ape sh*t once signal hits 5v with high boost. A dyno tune is always good to have done after install so you can get the afr's in check.
Old Feb 25, 2017 | 04:29 PM
Shirvaan's Avatar
E55
Any advise on where to place this ?
just got the map clamp today and want to fit it next week
Going 77sc and 185mm cp
Old Feb 25, 2017 | 06:14 PM
new55's Avatar
04 55
dont mean to hijack thread -- how does weistec get that kind of boost along with the fixed sc pulley and not have any issues ?
Old Feb 26, 2017 | 10:46 AM
Roverron's Avatar
ML63
They know how to tune the file deeper.
Euro tuners can alter the files better and deeper.
Old Feb 26, 2017 | 06:25 PM
Hulk's Avatar
A Merc
Jerry figured out to get over 19psi here
https://mbworld.org/forums/w211-amg/...tml?styleid=19
Old Feb 27, 2017 | 06:21 AM
new55's Avatar
04 55
thats a Weistec blower and fixed pulley with a EC tune --i wonder why the fixed pulley with OEM blower has issues like the infamous hiccup
its an enigma
Old Feb 27, 2017 | 07:17 AM
Hulk's Avatar
A Merc
Fixed pulley or not makes no diff
He went over 18psi so jerry can do it
Old Feb 27, 2017 | 01:32 PM
EREBUS's Avatar
All you need to do is to splice the wires going to the map sensor. I made the wire long enough to place the Map Clamp in this location....
This video explains and helps with the install!
Old Feb 27, 2017 | 01:36 PM
EREBUS's Avatar
Well, this turned awkward quickly. lol
Old Feb 27, 2017 | 02:53 PM
Shirvaan's Avatar
E55
Thanks buddy
Your setup looks sick
https://www.youtube.com/watch?v=coZVHLkzM7I
Old Feb 27, 2017 | 10:54 PM
tlambert's Avatar
2005 E55 AMG
^^^^ that's a whole lotta business going on in there!
Old Mar 2, 2017 | 08:34 PM
95ONE's Avatar
Subies
I make 511whp at 14psi. Curious what you're making at 20..
Old Mar 4, 2017 | 10:01 AM
albania's Avatar
e220 cdi 2005
after driving normally for 200km I had the same problem. It is not taking more than 3000 rpm and more than 140 km/h.
I restarted the car and was back in normal. No check lights on the dash.
any idea what to do?
Old Mar 5, 2017 | 11:36 PM
Hulk's Avatar
A Merc
You are not a sponsor here and no one knows you. You will get banned
Old Mar 6, 2017 | 06:05 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Hope not. He seems to know his way around in the computers. That is a rare and valuable thing.
Old Apr 3, 2017 | 01:27 PM
Shirvaan's Avatar
E55
So i I fitted the crank pulley without the map clamp and it drives fine
onky issue now is the charger is shutting off at 230kmh
is this due to the clamp nt fitted ?
Old Apr 3, 2017 | 09:01 PM
Rob CL's Avatar
Not sure of your specific build, but it sounds like you're overheating the charge air man. Been watching the IATs? Coolant pump in good order?
Old Apr 4, 2017 | 08:23 AM
This doesn't look like the thread I posted this in! I guess he did get banned.
Old Apr 5, 2017 | 01:09 AM
EREBUS's Avatar
This was my first data log in a recent mile event a few weeks ago. I built an entirely new intercooler system and was running it on the CLS for data. My heads were lifting and blowing coolant out the reservoir during these data logs. These figures were taken with the Map sensor (clamped) after all three water to air intercoolers. I should have over 20 psi once I remove the factory intercooler (working on intercooler revision #4)
Map clamp only. No fairy dust or bullsh*t tuning claims.
Yeah, the IAT's? 89 degrees at the airstrip. Engine Bay tank was iced down (2.25 gallons) and using 49 meth/ 51 water. Wicked burn out jumped my IAT's a tad and sitting in staging didn't help. Regardless, not a system out there could do that. That's over a mile @ WOT. Just say'in?
