Crank pulley came off after having crank seal replaced.
Old Dec 1, 2015 | 11:41 PM
Wheel deal's Avatar
04 e55
Does anyone know of any shops beside the stealership that can fix. I'm between Raleigh and Richmond.
Old Dec 2, 2015 | 06:31 AM
2000UZJ's Avatar
E55
Is the pulley off the crank shaft completely or loose and wobbling? Mine friction welded itself to the crankshaft and was a disaster. Don't start/run it. No shop recommendations from my end other than best of luck
Old Dec 2, 2015 | 01:11 PM
Wheel deal's Avatar
04 e55
It came completely off. It's nothing to hold it in place.
Old Dec 2, 2015 | 01:36 PM
Denroll's Avatar
'06 E55
Who did the work and how many miles were on it since the seal was replaced?
Old Dec 2, 2015 | 01:37 PM
chawkins2001's Avatar
2006 E55 AMG
Post a pic of what your crank snout looks like. You have a couple of options.
Old Dec 2, 2015 | 02:28 PM
E55Greasemonkey's Avatar
This place is a joke.
Take it back to where the work was done. If the bolt wasn't tightened with at least a 5 foot long ratchet (1" drive) it wasn't tight enough. No, I'm not kidding.
Old Dec 2, 2015 | 02:40 PM
Denroll's Avatar
'06 E55
And ask if they reused the crank pulley bolt. It can NOT be reused. It's a torque-to-yield bolt a.k.a stretch bolt.
Old Dec 2, 2015 | 04:06 PM
Wheel deal's Avatar
04 e55
I drove the car about 300 hundred miles before it came off
Old Dec 2, 2015 | 04:07 PM
Wheel deal's Avatar
04 e55
I'm not for sure about the bolt
Old Dec 2, 2015 | 06:59 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Take it back whoever did the work. They are at fault for this failure. What does the pulley, and bolt look like? I have a crank with a good snout if needed.
Old Dec 2, 2015 | 08:41 PM
BC928's Avatar
2006 E55, Various other German and ‘Murican
Jesus these people that feel or think "Tight is good enough".
I am sure there is a torque setting for this bolt. And I am sure it is big. I don't have the WIS open, but it has to be in there. These are Germans for Christ's sake. There WILL be a spec - somewhere! Probably 150-250lbft. Possibly that in Newton Meters.
Old Dec 2, 2015 | 09:39 PM
SPatykAMG's Avatar
W211 E55
its really high I want to say 240 plus 90 degrees
Old Dec 2, 2015 | 10:33 PM
Wheel deal's Avatar
04 e55
How much for the crank and why did you replace it?
Old Dec 2, 2015 | 10:54 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Craig will chime in again. He has first hand experience on this
To me the crank looks ok. Will need a couple pins to hold the pulley.
Old Dec 3, 2015 | 07:51 AM
Wheel deal's Avatar
04 e55
Ok. Thanks. That will be greatly appreciated.
Old Dec 3, 2015 | 11:42 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
stock pulley came off a M275 V12TT
