end of warranty bug hunt - what shall we look for?
Old Feb 7, 2016 | 09:58 AM
Toadster's Avatar
2005 E55 AMG
Exclamation end of warranty bug hunt - what shall we look for?
my 4-year 60k mile warranty runs out in 2 weeks - seriously can you believe I've owned this car 4 years (and only 44k miles)
so I talked to my SA and he said to bring it in to do an inspection to make sure there are no surprises...
I've had lots of stuff done - keyless Go has been the most common culprit - they've replaced the shifter knob 3 times, and each door handle at least once
the shifter knob usually needs wiggling to get the keyless to start - seems to me like a contact issue in the shifter, not the knob... thoughts?
also - other items to check?
airmatic has been good so far too...
Old Feb 8, 2016 | 03:42 AM
Rocman8's Avatar
E55
Valve covers or rear main leak. Engine/trans mounts, lower control arm/thrust arm bushings, ball joints, rear shocks leak or noisy. A/C and heater ok? Noisy pulleys. Squeaky a/c blower motor. SBC codes/issues. Panoramic roof motors.
Old Feb 8, 2016 | 03:46 AM
55Jeff's Avatar
2006 cls 55 amg
I would add subframe bolts as well to check on that list, idler pulleys specifically, keyless go seem to always break on these cars unfortunately. Other then that she will be golden enjoy !!
Old Feb 8, 2016 | 09:55 AM
Toadster's Avatar
2005 E55 AMG
did the valve cover gaskets when i bought it, will check again though
rear main seal done last year
engine mounts done about 15 months ago
thrust arm bushings done about 15 months ago
ball joints have been fine so far
will definitely have them review the airmatic
pulleys are good, had them checked last month
a/c blower was already done
no SBC issues
had the pano roof motor replaced last year
dang!
Old Feb 8, 2016 | 09:58 AM
Toadster's Avatar
2005 E55 AMG
subframe bolts are a good one too - I'm not that hard on the car, but 500+ ft/lbs is a force to be dealt with
it amazes me that MB can build a 20K nearly bulletproof engine good for 200K miles, but door handles - OMG they won't last 12 months!
I even saw a Nissan Leaf with active door handles the other day, I wonder if they have the same issue?
Old Feb 8, 2016 | 04:19 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
What type of car are you driving? I see 05 e55.... Am i retarded or something, how does a 2005 still have a warranty??? Extended warranty?
flex discs
shifter bushings?
diff side seals?
sway bar noisy?
spring links have play? noise over bumps?
You could for the hell of it if you haven't already get you a new tank, pump x2, and pressure regulator.... just saying
is there a burr in your water pump? Does the pulley have "excessive" play...? peep the quotes. haha
Power steering pump noisy when cold?
EGR valve sticking at times???
Old Feb 8, 2016 | 04:28 PM
Rocman8's Avatar
E55
flex discs
shifter bushings?
diff side seals?
sway bar noisy?
No EGR on M113k
Old Feb 8, 2016 | 04:32 PM
cmriv's Avatar
No EGR on M113k
:w ord:
Old Feb 9, 2016 | 02:41 PM
mkiv_tdi's Avatar
Jetta TDI [Daily] , Audi A8L [Sold], '12 STI [Sold], '06 E55 [Sold], '05 S500, '15 GLA250
Not sure if you've replaced it or not, but is there a way to "prematurely" induce the SBC brake counter? That way you can get it changed within your warranty period and not worry about it for another 10 years?
Old Feb 9, 2016 | 04:12 PM
verminator's Avatar
2010 E63AMG
Ball joints (even if they have not been a problem), valve cover gaskets and transmission connector leakage...best wishes on getting the last little bugs, sounds like you've been staying on top of your beast's maintenance needs...
Old Feb 9, 2016 | 05:23 PM
Toadster's Avatar
2005 E55 AMG
yup! this car has been well cared for... its' taken good care of me in the process
Old Feb 18, 2016 | 11:40 AM
Toadster's Avatar
2005 E55 AMG
wow - they found a few things... $4.5k worth
i'll post it when i get it back
Old Feb 18, 2016 | 02:22 PM
cmriv's Avatar
must be nice!
Old Feb 18, 2016 | 02:34 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
My god ! I have my car for 7 years and my keyless go and door handles never have any problems. All 4 handles still works, lock and unlock !
Old Feb 24, 2016 | 08:49 PM
Toadster's Avatar
2005 E55 AMG
must be nice!
let's see...
new intercooler pump (DOA)
two front control arms (clunking)
2 rear air bellows replaced (sitting low, squatting)
had to pay for alignment and some subframe bolts
