Transmission issues
Old Jun 25, 2016 | 09:53 PM
Dato55's Avatar
2005 e55
Transmission issues
Took her to the track today and got around 4 runs in and on the way home I heard a very loud whining noise and eventually the check engine light came on and the cel was p0715 and went into limp mode which only gave me one gear but I was less than a mile away from home so I limped her home, any ideas as to what the problem is?
Old Jun 27, 2016 | 01:24 PM
djempirE55's Avatar
E55, Granturismo, F430, 993, E39, Jag
Originally Posted by Dato55
Took her to the track today and got around 4 runs in and on the way home I heard a very loud whining noise ...any ideas as to what the problem is?
It happened to me, turned out to be a female passenger. I resolved the issue by dumping her a$$ to the curb. No more whining.
Seriously, I hope you get it fixed.
Old Jun 27, 2016 | 01:36 PM
Dato55's Avatar
2005 e55
Honestly I'm not that worried because I have an aftermarket warranty and the trans is covered but just got it towed to get some diagnostics done.
Old Jun 27, 2016 | 06:04 PM
new55's Avatar
04 55
maybe an option while its apart and throw in a rear main while your in there
https://mbworld.org/forums/w211-amg/...er-review.html
Old Jun 27, 2016 | 06:54 PM
Dato55's Avatar
2005 e55
Already planned that because it has a slight leak but every shop I took it to said nothing to worry about but if it's out I'm definetly changing the rear main seal.
Old Jun 27, 2016 | 07:08 PM
Dato55's Avatar
2005 e55
For the 3k stall I heard many good things about but the only problem is the warranty might not cover a 3k tc.
Old Jun 28, 2016 | 05:21 AM
e36uc's Avatar
06 E55
off topic lol but i have a rebuilt tranny for sale
Old Jun 28, 2016 | 08:09 PM
Luxury4play's Avatar
E55
whine may be your trans pump
Old Jun 28, 2016 | 08:11 PM
Dato55's Avatar
2005 e55
The wine also stayed when put into nuetral
Old Jun 28, 2016 | 08:12 PM
Dato55's Avatar
2005 e55
Interested if warranty dosent cover, how much would you want for it so I have an idea on what I should do
Old Jun 28, 2016 | 09:40 PM
E55
the whine usually is from the pump starving for fluid, drop the pan and check the filter for clogs.
Old Jun 28, 2016 | 09:42 PM
Dato55's Avatar
2005 e55
The wine followed the revs even in neutral, would that still be a pump related?
Old Jun 28, 2016 | 09:44 PM
E55
when i had mine act up it did.
Old Jun 28, 2016 | 09:52 PM
Dato55's Avatar
2005 e55
Going to drop it probably tomorrow if not Saturday but I will take a look, I have a dip stick and when I checked the fluid it had the correct amount in it and it looked clean, the last time the fluid and filter was changed was around at 30 or 40k miles, I have 72k now.
Old Jun 29, 2016 | 05:18 PM
Dato55's Avatar
2005 e55
Dropped the pan and found small pieces of metal in pan today so just sent in a claim for a new trans, hopefully all goes well with the warranty company
