Superflo I/C Pump
Old Oct 16, 2016 | 10:43 PM
BlackHammer's Avatar
2006 E55
Superflo I/C Pump
I am hoping my IC pump is shot (another story altogether)...
Anyone familiar with this pump (link below)?
Sources tell me the Superflo the best option for the 113K.
Sources also tell me that the Mez pump is low pressure/high volume and even when they are working up to their potential aren't sufficient for a modified 113K.
Thanks,
TK
http://vrpspeed.com/index.php?route=...product_id=189
Old Oct 17, 2016 | 01:09 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Thanks,
TK
That is a pierberg CWA-100. It a great, high flowing pump. It is essentially the same pump used on all newer AMGs (with a different connector).
I have compared that pump head to head with the bosch 010 (and the peirberg CWA-50) and a couple of others and it is by far the best flowing pump for the money (particularly when measuring Flow at typical charge cooling system resistance).
After testing various pumps, the CWA-100 is what I ended up using on my SL55.
I would not hesitate to get this pump from VRP it is a very good price for a great pump.
hope that helps,
Chris
attached is a graph comparing it to various pumps. I did not create this graph, but all of my testing on various pumps, agreed with it.
Attached Thumbnails Superflo I/C Pump-pumpcharacteristics130421-page-2_zps9500e15f.jpg
Old Oct 17, 2016 | 10:02 AM
2006 E55
Latemodel21,
Thank you! Over the top response (you are too kind). Hopefully I am not pushing it here but do you know if the pump can be set-up to where it is continuously running?
Thanks,
TK
Old Oct 17, 2016 | 10:44 AM
Latemodel21,
Thanks,
TK
Yes, it can be set up to run anytime your key is on, etc.
Keep in mind that this pump pulls about 8 amps (8.4 at start up and 7.2 to 7.35 thereafter in my testing) which is more than twice that of the 010. SO, you will want to run heavier wires and fuse it at 10 amps or more (I use a 10 amp fuse; mercedes uses a 15 amp fuse in newer cars that run this pump) .
hope that helps,
Chris
Old Oct 17, 2016 | 12:25 PM
2006 E55
hope that helps,
Chris
"Yes" and "Big time". Assuming I will have to do the same thing when I add a trunk tank with Mule pump (?).
Old Oct 17, 2016 | 02:53 PM
seanol's Avatar
2004 AMG E55
When it comes time I will show you how to wire up a relay to ensure proper power with no issues.
Old Nov 2, 2016 | 08:50 PM
spastik monkey's Avatar
Veteran: Army
Chevrolet Traverse, Honda Cbr1000RR
How's the install on these?
Old Nov 3, 2016 | 01:46 PM
2006 E55
Install is complete but the car is still at the shop and trying to work out a few "bugs". From what I gather it flows excellent and was set up to run when the key is in the ignition!
TK
Old Nov 3, 2016 | 06:21 PM
Hulk's Avatar
A Merc
They better have used heavier wires and a fuse
Old Nov 3, 2016 | 06:59 PM
seanol's Avatar
2004 AMG E55
A relay was used with heavier gauge wire to pump and battery point at front SAM. I believe stock wiring triggers the pump.
Old Nov 3, 2016 | 09:16 PM
Sosa's Avatar
2006 E55 AMG, 2018 E63S Wagon, 2018 991.2 Targa GTS, 1992 R32 GTR and 2019 Ford Raptor
Do you have to use a heavier gauge wire and fuse if your just plugging it in were the factory location? Using the VRP pump.
Old Nov 3, 2016 | 09:26 PM
Hulk's Avatar
A Merc
Yes you need heavier wiring. It takes 7-8amps, much more than the Bosch takes
Old Nov 3, 2016 | 10:01 PM
Sosa's Avatar
So how far up do I need to run the heavier wire? Example, VRP supplied the pig tails. I basically cut the factory plug and wire it in at that point with the pigtails that the pump supplied with.
Old Nov 3, 2016 | 10:30 PM
Hulk's Avatar
A Merc
It's a pierburg cwa 100 no matter what anyone renames it lol
You should run a relay with heavier wiring and a fuse
Old Nov 3, 2016 | 10:34 PM
seanol's Avatar
2004 AMG E55
You would run the heavy gauge wire from pump to relay. At the relay you would run one heavy gauge to the battery power, one smaller wire to ground, and one wire from the original IC pump as the turn on signal. Ground the pump with heavy gauge wire (same size as power wire) no farther than 18 inches from pump.
That help?
Sean
Old Nov 3, 2016 | 11:17 PM
Sosa's Avatar
Ok, thanks gentlemen.
Old Nov 3, 2016 | 11:24 PM
2006 E55
Hulk, For all it matters it replaced a Mez pump...
Thanks for the advice on the heavy wiring.
Also, "Chiller Killer" is fixed. Wasn't the KC. I had leaks coming from my a/c lines. it was 68 today and rolling IAT's dropped as low as 48. Did a few pulls to unsafe speeds and IAT's went to 170 range. The shop is moving the return line to the back of the engine bay tank. Hopefully that helps. As far as the wiring goes they will have the S/C off sooner than later for a few more "goodies" that should rid me of any IAT issues (even with a 225 crank and 50 FSP set-up)...
225/50 is an exaggeration but you guys get the point.
Old Nov 4, 2016 | 09:15 AM
Hulk's Avatar
A Merc
Mez is a low flow pump big diff. Also you need a pickup line in the bay tank. If you took that out you will have issue
Old Nov 18, 2016 | 07:03 PM
Veteran: Army
Anyone have a pic of where they mounted? Everywhere I try to stick it hits the PS hose.
Old Mar 16, 2022 | 11:16 AM
Ajai Thomas's Avatar
2006 SL55 AMG
@hulk - i know that the cooling fan has a direct connection to the ECU. My ECU got all screwed up where the cooling fan was turning on as soon as i turned on the car. I found another thread that helped me diagnose this issue. Without the heavier wire and larger fuse, would this have caused the ECU chip that controls the cooling fan to "short circuit? have you observed this or heard of anyone else with this issue?
