Fuel filter location and service interval
Old Dec 20, 2016 | 06:30 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
Is fuel filter in tank on Right side (passenger side) just the same as other W211's for the E55? When looking at images it looks like a twin pump assembly versus my E320's single assembly? Can anyone shed some light on proper part Number, location and service interval if possible?
THANKS!!
Old Dec 20, 2016 | 07:06 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Service interval is every 60,000 miles, I forget if there is a timespan. Unfortunately the fuel filter and the fuel pump are in one integrated unit. Thus meaning you have to replace the pump as well. Meaning the job escalates to several hundred dollars. The interval is mentioned in the E55 AMG specific download-able service manual available off MBUSA.com.
Old Dec 20, 2016 | 07:28 PM
Redwood415's Avatar
yes, I am finding out there are many changes to the AMG fuel system versus the normal W211. Thanks for your help..
Old Dec 21, 2016 | 03:29 PM
Elhonaz's Avatar
W211 E55 2003
fuel PUMPS are on rightside of the saddle tank. Fuel sender unit with integrated fuelFILTER is on the left side
Old Dec 22, 2016 | 02:25 AM
Rocman8's Avatar
E55
+1
Old Dec 22, 2016 | 11:53 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
And don't forget to replace the relay hidden under the right-side panel of the trunk (no access panel). You'll find the air pump relay next to the fuel pump relay so if you aren't sure which is which, just replace them both. You can usually recognize the fuel pump relay because it melted....
Attached Thumbnails Fuel filter location and service interval-w211-e55-2005-fuel-pumps-relay-location.jpg   Fuel filter location and service interval-20150705-relay-fuse-2.jpg
Old Dec 23, 2016 | 03:04 AM
Max.H's Avatar
E55
Right side as in passenger side?
Old Dec 23, 2016 | 09:06 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Fuel pumps are on the fuel filler cap side. Fuel sender unit with integrated filter is on the driver's side in a left-hand drive US car. Replace them as a set. You'll need two of the O-ring seals also. Plan on $950 in parts. You'll need the proper adapter cables or one of the pumps will run backwards and you wont be able to connect to the pressure regulator on the sending unit. This is not a cheap maintenance item....
Here's a list of part numbers and costs from my car in June of 2015:
211-470-00-00 Fuel Sending Unit (dual pumps) $411
211-470-64-94 Fuel Pump Assembly (actually filter and regulator) $489
211-471-05-79 Fuel Sender Seal x 2 $34
211-440-05-07 Cable Harness adaptor for fuel sending unit $15
211-540-07-00 adapter cable to fuel pumps $15
002-542-19-28, relays 2 each, $17
Old Dec 23, 2016 | 11:12 AM
Max.H's Avatar
E55
A favorite ebay seller has pumps and filters for about 1050. I see the relays and the seals. But, no adapter plug. I sent him my vin and he said plug in no adapter needed for 2005. It that right?
I need to change mine it's been 3 years since last change and the pumps on the passenger side are starting to leak.
Old Dec 23, 2016 | 07:27 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
With the above part numbers, you must have the adapter cables. The numbers listed are (IIRC) the fourth iteration of parts MB installs in the car.
Go with ECS Tuning for the parts and go by the VIN.
Start reading on page 2 of this thread. Several of us went round and round about this issue back in summer of 2015.
https://mbworld.org/forums/w211-amg/...cements-2.html
The latest iteration of fuel pumps has one wired with different connections than the previous version of fuel pumps. Thus the adapter cable.
https://mbworld.org/forums/w211-amg/...ml#post6938718
Old Dec 24, 2016 | 12:05 AM
Max.H's Avatar
E55
OK will go with ECU then. But, Still don't get it.. I checked out thread. So, they changed it. Why? Whats the difference from 1st to 4 gen. It's confusing why are they still selling old versions and what benefits does the 4th gen give over a plug and play older version. Both being new.
Old Dec 24, 2016 | 07:48 AM
Worth the wait's Avatar
2006 E55
If they are leaking why don't you get them covered under the recall for free?
Old Dec 24, 2016 | 08:16 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Here's the latest out of the EPC for my car's VIN (2005 model year). Seems even more pieces are added. FWIW, one of the updates is a piece of foam that is placed on the underside of the metal lid over the fuel pumps and their harness; looks like it is intended to prevent the electrical harness from rubbing against and shorting out against the metal lid. I know that when I pulled my old pumps, the OEM electrical harness was blackened and insulation was cracking off the wires where they were laying against the metal lid; I had to refurbish the connector.
See attached. If you want to be sure, post your VIN and I'll look it up in EPC for you.
Attached Thumbnails Fuel filter location and service interval-fuel-system-part-numbers.jpg
Old Jun 18, 2017 | 09:48 AM
supreame's Avatar
W211 E55 AMG
Did you ever happen to find out the reason why those other parts are included as ancillary with the 2114700000 pump? I searched for 2115459040 and 2115458940 (they are brackets, one appears to be in the right wheel housing and one is for the "bass box" ) and 2114405508 is the harness including relay. Any idea if this harness is an upgraded part or are they just recommending replacing it because it's more than likely soaked in fuel or burnt?
Old Jun 18, 2017 | 01:58 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Not sure about the bracket for the brakes (WTH?) but the 2114405508 (harness including relay) I assume (I have not and did not order one) is to replace the melted relay and socket that far too often occurs with the E55's original single-relay design.
See here for where I recently upgraded my fuel pump relay and socket. Be sure to read the whole thread.
https://mbworld.org/forums/w211-amg/...intenance.html
Old Jun 18, 2017 | 10:40 PM
supreame's Avatar
W211 E55 AMG
Yeah, not sure what's going on with the brackets. Thanks I'll have a read.
