P2540 pops-up when I connect a scan tool
The car had 955xx miles on it, and was in top-notch condition.
On Monday morning, I took the car to a state inspection station.
They failed me because their equipment couldn't connect to the computer.
I took it home and I was able to connect to the computer only with the key in the "ON" position... engine not running.
I also noticed that when my scan tool connected to the computer, the "check engine" light illuminated. I found a P2540. I cleared it, and it didn't come back.
I took the car to the inspection station this morning, and told themto try connecting with the key on, engine off. That worked, but therewere not enough "ready" codes set to pass inspection... bummer.
I took my second "fail" papers and left. When I got back in the car, the "check engine" was illuminated again. I cleared the code with my scan tool.
I searched this forum and part of the internet, and I was unable to findany other folks that mentioned a code popping-up when they connected a scan tool.
I am a "frugal" guy, and I don't want to simply take it to the dealer.
I need suggestions on how to get this car to pass inspection.
Thanks,
That's the drive cycle to get the ready codes set.
Your fault code is: P2540 - Low Pressure Fuel System Sensor Circuit Range/Performance.
Hopefully it is just a sensor issue. If not, figure it out quickly because you can destroy your engine if fuel pressure is insufficient to maintain proper air/fuel ratios. May be as simple as a clogged fuel filter. May be the pumps are going bad.
scan tool.
a scan tool.
Thanks,
If it is coming back on after being cleared there is a hard fault that needs to be resolved.
In this case it looks like the fuel pumps have a fault the needs to be resolved (replacing fuel pumps).
https://mbworld.org/forums/c63-amg-w...uel-sytem.html
^+1 on what Barry linked up, you maybe able to clear it then meet the drive cycle requirements to pass without replacing the pumps but I guess I am still stuck with a gut feeling that the car is reporting the CEL as the pending fault that had its final fault criteria met and triggered the CEL lamp to activate.
Regardless of your pass fail it probably would be a good idea to see if you could get a SDS scan tool hooked up to see what is going on
But...
If it were a real fault, wouldn't it illuminate the "check engine" more often instead of only when a scan tool is connected?
I have driven the car well over 100 miles since I bought it. It only triggered the code when I connected a scan tool.
After I cleared the code, I drove it for nearly an hour before I got to the inspection station. As soon as they connected their scan tool, it triggered the code.
Both codes were triggered with the key on and engine off. Could that be the only time the computer checks the fuel pressure?
I have KEYLESS GO, so I usually sit down, step on brake, and push the button. The car is usually in "key on, engine off" for only a moment... hmmm.
Maybe I'll start the car with a key for a couple days and see if I can get the P2540 to come back without a scan tool.
Are there codes that are only triggered when a scan tool is connected?
Thanks for all the help,
After work, I started the car with the key... flipping the key to '2' and letting it sit there for a few seconds before starting. I saw no 'check engine' light.
I followed the OBD II drive cycle as best I could on the way home... idle for a few minutes ,then drive certain way for a while. I saw no 'check engine' light on my 28-mile trip home.
This morning, I started the car with the key... flipping the key to '2' and letting it sit there for a few seconds before starting. I got my 'check engine' light right away! ... without connecting a scan tool.
So... I'm concluding that the scan tool was not the reason for my code; it must have been the sorry, low-down, good-for-nothing seller resetting the code and hoping the test drive didn't trigger the code before he sold it
What should my next diagnostic steps be?
I need to get plates on this thing, but I can't do that without passing the inspection
Meanwhile, I was able to use Torque android app on the way home. I saw fuel pressure values between 50 and 60 all the way home. What is the fuel pressure supposed to be?
If you put it on a diagnostic system, go to Control Units/Drive/Fuel Pump and you can read out the measured values to include pressure and amperage draw by the fuel pumps.
Your car is telling you the fuel pressure is low. Pumps, filter, or sensor. One or all of them are bad. If it is only one pump, the low pressure would only show up at full throttle and higher rpms.
Trivia for the day. If one replaces a fuel pump controller, it must be activated using Star or malfunctions can occur.
I bet, fuel pumps/sending unit + SDS would be cheaper than having just the pumps done by a dealer
Is the OE system a return-style [pump, regulator, return line] or is it a returnless [pump, pressure sensor, computer-controlled voltage] system?
Returnless. Just like the E55. Do a search on "E63 fuel system" or "E55 fuel system" and you'll find an image. Or better yet, sign up with the Electronic Parts Catalog and you can look up the latest parts yourself.
Research, research, research. The truth is out there.
The OE pumps are significantly different compared to the Walbro in-tank pumps I'm familiar with, so I won't be installing aftermarket pumps.
Plus, I have no idea if the current-draw and flow characteristics of the OE pumps are even close to those of the Walbro pumps - I'd hate to BBQ the FP controller.
I ordered the fuel pump assembly [211-470-36-94] and the sender assembly [new part number 211-470-63-94] from my local dealer. They matched the pricing I saw online! Plus I won't have to pay for shipping!
I'm on a deadline... once you fail a TX state inspection, you have 15 days to correct the problem, or you have to pay the inspection fee, again. Today is day #7.
If anyone needs photos of E63 fuel system parts, speak-up, and I'll see if I can get them for you.
On a side note...
I was surprised to find VW / Audi logos on a couple of the connectors I encountered. Isn't that like finding Ford parts on a Chevy?
I put the pumps and filter in on a Friday evening. I got around to plugging-in everything and discovered that the updated filter assembly has a different wiring connector on the top of the module
I tracked-down the 211-440-05-07 that I needed at the dealer in Plano. Early Saturday morning, I picked it up and everything went back together with no issues. The car started and ran just fine.
I followed the OBD-II drive cycle recipe on my trip to the inspection station [27-28 miles away]. I pulled-over to check for codes and ready flags just before I got there. Enough flags were 'ready' and I had no codes!
I passed inspection with ease... I had one entire day to spare of my 15-day window.
I've been driving it since then with no issues... other than only getting about 18 mpg when I was used to getting 48.
This car doesn't have the low-end grunt like the E55s I drove, but the interior is so nice and I couldn't pass on the price
