Supercharger pulley pins
Old Jul 28, 2017 | 02:09 PM
cmpcpro's Avatar
2004 CLK 500
Hey guys I'm replacing my supercharger pulley with an new 83 from Eurocharged and when I took it off I noticed the two pins for the shaft were broken and they came out with the spacer.. any ideas what I'm supposed to do now? Thanks guys!
Old Jul 28, 2017 | 04:28 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You can put the washer on without the dowel pins and you will be fine.
Old Jul 28, 2017 | 04:47 PM
cmpcpro's Avatar
2004 CLK 500
Thanks shardul! So when I took it off the old pulley slid right off.. now the new one doesn't want to go on and neither does the old one lol.. I've cleaned the shaft and it has no burrs and I put a little oil on it but still nothing.. I also tried heating the pulley at 170 for 15 min in the oven and that did absolutely nothing.. do you know what I should do? Thanks!
Old Jul 28, 2017 | 05:00 PM
shardul's Avatar
it is a very tight fit. use a rubber mallet and tap and rotate and it will slide on
Old Jul 28, 2017 | 07:44 PM
cmpcpro's Avatar
2004 CLK 500
Thanks shardul!! It's on and everything is back together.. I didn't change any of the shims because Eurocharged told me as long as I can get a credit card in the gap and it's not tight but not loose it should be fine and that's what it was with the factory pulley.. it's about the same with the new one maybe a hair bigger.. the card will fit but I have to put it in very gently to stay up without falling into the space.. I measured the card and it's .75mm.. keep in mind this is with the motor cold (hasn't run in days).. should this be checked when cold or when the engine is warm? Do you think I'm okay? Don't want to take this thing off after what I went through and after the loctite! Thanks again for your help!
Old Jul 28, 2017 | 10:41 PM
shardul's Avatar
You should be fine
Old Jul 28, 2017 | 11:10 PM
cmpcpro's Avatar
2004 CLK 500
Originally Posted by shardul
You should be fine
Thanks again shardul I guess I'm glad I didn't take the shim out.. I just drove it and shut the motor off and now there is no gap!! It must not be close enough to stop it from spinning freely because it does but I can't get my credit card in there, so guess checking it while hot is the way to go!!
Old Jul 29, 2017 | 08:31 PM
cmpcpro's Avatar
2004 CLK 500
You should be fine
Hey shardul, I want to thank you for all your help! I installed my 83mm supercharger pulley yesterday and the gap seemed on the large side but after a drive it's nice and tight now! However I noticed one of the rivets on the pulley holding the spring seems to be crooked... damn!!! Do you think I should make Eurocharged replace it or do you think it will be ok? Thanks again!!
Here is a picture of it and one of the other ones.
Attached Thumbnails Supercharger pulley pins-img_0187.jpg   Supercharger pulley pins-img_0186.jpg
