airmatic stiff ride in the rear
Old Aug 13, 2017 | 12:32 AM
RRnelcheeze's Avatar
CLS55
CLS55 with Renntech v1 ELM (posting here since we do share the same suspension)
So i had a leaking drivers front airshock, replaced it, drove for a test drive, the air link on the top of the shock popped off so the whole car dropped to the ground, fixed this problem (it was a used shock so the threads were a bit loose) The car aired up fine, its level, it goes up and down with the raise button but now the rear is really stiff, like undrivable stiff. any ideas?
thanks!
Old Aug 13, 2017 | 09:30 AM
new55's Avatar
04 55
put the cat on a STAR system and check pressure - the airbag acts like a spring
Old Aug 14, 2017 | 01:12 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
have you turned off the ELM then cycled through all suspension modes? sounds like your rear shocks are stuck in a stiff setting. our cars have height and dampening adjustment.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 15, 2017 | 12:58 PM
SICAMG's Avatar
2005 e55 AMG
Disconnect and reconnect the two sensors at the top of the shock tower up front....right near the strut mount. You will see two identical sensors on each side. The rears will be the same I believe.
Old Aug 15, 2017 | 02:29 PM
CLS55
I will try that.
Old Aug 15, 2017 | 02:30 PM
CLS55
I did, turn off the ELM just so I could try to isolate the issue
Old Apr 14, 2021 | 01:18 PM
progonat's Avatar
2003 E320
For those who are reading this in 2021 and beyond this problem explained in detail here: https://www.youcanic.com/wiki/merced...ff-bouncy-ride
Old Aug 23, 2023 | 01:03 PM
IIGW's Avatar
2006 E500
no its not..
dead link
here is the correct one
https://www.youcanic.com/mercedes-be...ntrol%20module.
Old Aug 23, 2023 | 02:02 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Thank you @IIGW !
Old Aug 26, 2023 | 08:09 PM
bobgodd's Avatar
2004 E55
I'll say it's not always this. I ended up replacing all four corners due to age and the ride was still rougher than I thought it should be. Ended up replacing the compressor because it started chattering and bingo, ride was normal again.
