180 crank, got a 83mm, should I even install it?
Old Jan 9, 2018 | 09:37 AM
MACEDON's Avatar
05 E55, 98 CLK320
I made the mistake of buying a 83mm pulley without thinking too much about it, my 90mm is on it's way out and needs a new bearing so I thought I should just get a bit more power while I'm at it.
Now I'm not so sure if my car is even ready for such a thing...
What should I look out for with my stock injectors as a tell tale sign that they need to be upgraded for 550c? Am I to log something? Don't have a wideband so probably nothing...
Will my crankshaft be in jeopardy? I saw some thread about pinning the shaft and with my big pulley it got me worried.... I really wish the car just came with a stock crank when I bought it.
Old Jan 9, 2018 | 09:42 AM
oneslow55's Avatar
E55 amg
Well your entering the factors of more heat and stacking .You'll need larger injectors cause you’ll be at state of lean out and can pop your engine as your injector duty cycle is maxed !I hope you got cooling mods for this combo .
Old Jan 9, 2018 | 11:40 AM
MACEDON's Avatar
05 E55, 98 CLK320
I don't have meth if that's what you're hinting at. I don't track the car but I do live in a hotter state...
I have a PLM cooler and a 010 pump currently.
Old Jan 9, 2018 | 11:57 AM
MACEDON's Avatar
05 E55, 98 CLK320
If I do upgrade injectors what is the best kit to buy that will be plug and play?
Looking for reliability and ease of install
Old Jan 9, 2018 | 01:20 PM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
you can go with 550s or 630s i have a new set of 630s for sale with the pigtails .... they both are easy to tune for just have to tell jerry or tony what size u have an they can send u a modified tune. I bought this set bout 2 monthes ago an couldnt find em so i bought a new set 2 weeks ago installed em an then while cleaning the garage found my other set lmao. So ill give ya a good deal if interested. I love mine they work great.
Old Jan 9, 2018 | 01:25 PM
MACEDON's Avatar
05 E55, 98 CLK320
Where'd you get em from? Brand new right?
Old Jan 9, 2018 | 01:27 PM
E55amg0220's Avatar
Veteran: Air Force
brand new never installed .... i got them off ebay their the same ones vrp sells. They are bosch ... if u want i can install em an make sure they work perfect its pretty easy. Ill give ya a warranty on them they are perfect theres pics on my thread in this forum
Old Jan 9, 2018 | 01:29 PM
E55amg0220's Avatar
Veteran: Air Force
brand new never installed .... i got them off ebay their the same ones vrp sells. They are bosch ... if u want i can install em an make sure they work perfect its pretty easy. Ill give ya a warranty on them they are perfect theres pics on my thread in this forum took the pics this morning
Old Jan 9, 2018 | 01:31 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
You will need to upgrade your cooling to run the 180-83.
Id say Superflo, Secondary HE, and a bay or Trunk tank (trunk is best) would make it ok for you.
Old Jan 9, 2018 | 02:06 PM
MACEDON's Avatar
05 E55, 98 CLK320
Is the superflo pump a plug and play kit or will there be tinkering with the wiring?
Old Jan 9, 2018 | 02:17 PM
SPONSOR
E55 C63
It is a 2 wire pump, you will need to cut and splice into the factory wires
Old Jan 9, 2018 | 02:57 PM
MACEDON's Avatar
05 E55, 98 CLK320
https://mbworld.org/forums/w211-amg/...-i-c-pump.html
^what about all this?
I'm not opposed to getting the pump at all I'm just not too good with electronics, I'd hate to end up frying something 7-8 months down the line. I daily the car and take it on road trips.
Old Jan 9, 2018 | 03:00 PM
SPONSOR
E55 C63
We do not sell 4 wire configurations anymore. 2 wire only.
Old Jan 9, 2018 | 03:02 PM
MACEDON's Avatar
05 E55, 98 CLK320
And because of that I don't need to reinforce anything or what
Old Jan 9, 2018 | 03:05 PM
SPONSOR
E55 C63
right. The pump runs great on factory wiring, some customers prefer to run a dedicated wire from the fuze box so its always running under switched power.
Old Jan 9, 2018 | 04:37 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You can have your tuner command the IC to be on all the time via ECU calibration.
Old Jan 9, 2018 | 06:09 PM
Das_it16's Avatar
2004 E55 AMG
Do you at least have long tube headers? If not, don't stack pulleys. You'll just be adding more heat with no benefit. Depending on elevation you might even go over 17psi and hit limp mode but that's if your sea level and your DA is less then 500ish. My DA is always around 2800-3300 in Vegas and when I go on trips to SoCal I gain about 2-4 psi due to being closer to sea level. One time I was at PCH right by the beach I went from seeing 12-13psi in Vegas to 17psi at Newport beach. That was when I was 77/168 stack similar supercharger spin rate of a 180/83 but with mid length headers. I bought long tubes immediately after this incident.
Even with just mid length headers I wouldn't go anything over a 185 crank or equivalent.
I would replace the bearing of the stock supercharger pulley for now if i was in your shoes.
Old Jan 10, 2018 | 08:20 AM
MACEDON's Avatar
05 E55, 98 CLK320
I have mids. The pulley was sold to me by what should be a very experienced vendor who should know this type of stuff... and he's located in a very low lying state just like me.
I'm in FL, so what you said kinda scares me. I'm not really planning on getting bigger headers honestly, so maybe I should just put the pulley up for sale and chalk it up to a nice $50-60 lesson.
Old Jan 10, 2018 | 08:36 AM
oneslow55's Avatar
E55 amg
Your mods are fine ,long tubes will help your get maximum gains out your engine more so then cooling say vs your mids .The long tubes will help you run a tad more timing from the extra flow and psi drop which Compensate boost and timing when tuning .You need more cooling maybe a other he or one massive one to stop heat .These cars suffer when you go past 180 or 77 ,don’t forgot you’ll need more fuel too!!
Old Jan 10, 2018 | 11:15 AM
hayseed's Avatar
04 e55
good call -- it may save you money and aggravation in the long run
Old Jan 10, 2018 | 02:21 PM
Das_it16's Avatar
2004 E55 AMG
Back when I was I was stacked I was 77/168, mid length headers, 82mm tb , 2 heat exchangers, 10 gallon trunk tank, 550cc injectors with looped fuel rail. You need meth to cool
it down from climbing too high. The car would just gets too hot especially in the summer. The ecu pulls timing at 3 tiers:
95F - 3.5 degrees
113F- 6.3 degrees
149F - 9.5 degrees
My cooling still wasn't enough in 75F weather. My temp would start at 56F with ice and get to 129F on a 3rd gear pull at the dyno. I would recommend adding a meth kit to stop the temps from climbing so high. I added a 10 nozzle post inter cooler and a 3 nozzle on top of the snout. My temp wouldn't climb higher then 95F via zeitronix ndash on a 3rd gear pull at the dyno.
If you’re on recall fuel pumps I wouldn’t do it either. I lost a compression on cylinder #8 within 6 month of using a 77/168. I would upgrade the fuel pumps and drill some holes on the sides and bottom of the fuel buckets. To help refill the bucket so the pumps are always have fuel to pump. The new recall fuel pumps don’t have a siphon jet in the bottom of the fuel buckets like the original buckets that first came with the car causing a fuel pressure drop and going lean.
This issue doesn’t allow the fuel buckets to refill the buckets with fuel fast enough which causes the fuel pumps to not pump any fuel during a pull. If the pumps aren’t pumping any fuel they'll over heat and cause the fuel hat to get burnt. Which is what happened to me and unfortunately costed me a motor
ECU timing pull on the bottom left
Top view of the fuel hat
Bottom view of the fuel hat
Old Jan 10, 2018 | 02:29 PM
MACEDON's Avatar
05 E55, 98 CLK320
Jesus.
What I'm getting from this is that even my crank is too much. Definitely not interested in installing a meth kit that seems like such a pain in the ***.
It came with the car I didn't really even know when I bought it... I want to downgrade to a stock crank to be honest...
Old Jan 10, 2018 | 02:33 PM
Das_it16's Avatar
2004 E55 AMG
Jesus.
your 180 crank is fine for your current set up. I just don’t recommend you going anything higher like a stacked set up without doing supporting mods.
Old Jan 10, 2018 | 03:14 PM
MACEDON's Avatar
05 E55, 98 CLK320
I actually want to go down a notch... I have trouble keeping the heat off. I'm constantly running 22-30F over ambient.
Maybe I need to bleed my cooler again I don't know... I think getting that superflo pump might be the best money I'll spend, tough **** because I like JUST renewed my pump just a few weeks ago.
Old Jan 10, 2018 | 03:20 PM
Das_it16's Avatar
2004 E55 AMG
I would try the secondary heat exchanger first. It should lower temps pretty well. This is the one I used and its easy to install.
http://vrpspeed.com/index.php?route=product/product&path=101&product_id=211
