How to install AMG non-illuminated door sill plates
Old Feb 4, 2018 | 11:07 PM
Rovel's Avatar
2007 E63 Amg
Hi all,
I accidentally hit the AMG door sill plates with my foot when getting in the car and one side of it came off.
Does anybody know how to attach them back? These are original non-illuminated door sill plates.
Thanks in advance.
Old Feb 5, 2018 | 12:04 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
They just snap in. You'll need to buy some new clips since they break when you do that.
I did that within the first 3 minutes of owning my E63.
Edit: Are you talking about your E550? If so you're asking in the wrong section. I have no idea if your sill plates attach in the same way. This is the W211 AMG section.
Old Feb 5, 2018 | 12:59 AM
Rovel's Avatar
2007 E63 Amg
Thanks Man,
No, I sold the E550, and got E63. So your advice is applicable.
I lifted the plate and saw white color clips attached to the body. Somehow the plate itself detached from 2 clips. One is in place and still holding it. Should I pull it up from one side to remove it?
Old Feb 5, 2018 | 01:03 AM
Strigoi's Avatar
Originally Posted by Rovel
Thanks Man,
When mine came off it broke the white clips that you see. Same thing happened on an E350 that my boss used to have when his foot caught it.
Post some pics of the underside of the plate. It's been awhile since I had this issue and can't remember exactly what the setup looked like.
edit: Are the clips attached to the car and not the sill plate? If so, no worries. Just yank them out and buy some new ones. I can't remember exactly how they attach to the sill plate, but you didn't break anything most likely. The clips are cheap online as well. Buy extras so you have them.
Old Feb 5, 2018 | 08:45 AM
MACEDON's Avatar
05 E55, 98 CLK320
I glued mine in place with double sided tape. Same thing happened, second day of owning the car I kicked it off
Buy some 3M double sided tape and use a liberal amount
Old Feb 5, 2018 | 09:50 AM
Rovel's Avatar
2007 E63 Amg
HERE are the pictures of the underside. Do you think I can take those clips off and attach them to the plate again? How do I remove the one remaining ?
Old Feb 5, 2018 | 09:54 AM
w204_racing's Avatar
C300 sport 2008
if you can’t get the
clip to attach just use double side tap
Old Feb 5, 2018 | 10:13 AM
Rovel's Avatar
2007 E63 Amg
Thanks everyone,
I guess what I am asking for is how to remove it properly (since one of the clips is still holding it) without breaking. Then I will see if I can put the clips back it. If not, the tape will be the last option.
I just don't want to pull it up if that is not the right way.
Old Feb 5, 2018 | 10:48 AM
MACEDON's Avatar
05 E55, 98 CLK320
Kick it really hard and it will come off lol
But seriously just add a strip of 2 sided tape that **** will never come off again
Tape over the flat porion and that clip too all the way to the end and press on it.
Old Feb 5, 2018 | 04:50 PM
tlambert's Avatar
2005 E55 AMG
I agree with you so I’m going to try and help without telling you to tape it........wow lol.
If the pics will cooperate.
First, if the bottom of the panel isn’t broken where the white square headed clip attaches it will just slide back into the groove and should hold. To get the panel off you should be able to slide the panel towards the rear of the car just a bit and it lift up leaving the white clip behind just like the others.
Second, there are clip removing tools. You can probably get them from a local parts store similar to one of these.
Third, there is two parts to the clip. The tool will go in between the square head and the round bottom part that is pushed into the body of the car. Use the tool to pop the two pieces apart. If the top part comes out fine, inspect it and you may be able to reuse it. Same for the lower piece, leave it if it looks ok. If the clips need to be replaced the lower clip piece can be gently worked out with the tool or a very small flatblad screwdriver.
If you need to replace all the clips separate top from bottom, install the bottom pieces in the car, top pieces to the panel and then align the 2 parts
of each clip carefully when you are attaching the sill plate.
See the attached pics.
Old Feb 5, 2018 | 04:56 PM
tlambert's Avatar
2005 E55 AMG
Also this is when I took it off. Not installing it.
The two pieces of clips were apart when I installed them.
Old Feb 5, 2018 | 05:26 PM
Rovel's Avatar
2007 E63 Amg
Thanks so much!!!
This is what I was looking for. Now, I can see how those clips sit in there. I will just pull the remaining clips up and then try attaching the clips back to the plate.
Old Feb 5, 2018 | 05:30 PM
tlambert's Avatar
2005 E55 AMG
I think they may be reuselable if not broken. You should be fine.
Glad to help.
Old Feb 5, 2018 | 05:34 PM
tw2's Avatar
tw2
This is what I did also. The clips are very cheap, I think just a dollar each or something from pelicanparts. I have a few spare ones also.
Old Feb 5, 2018 | 05:38 PM
Rovel's Avatar
2007 E63 Amg
I appreciate all the help. Will pull the clips out tomorrow to see fi they are broken or not. I think the clips are OK, but the plate itself might not be. The clips have come off of the plate, so hope whatever holds the clips attached to the plate is still intact.
Old Feb 5, 2018 | 05:51 PM
tw2's Avatar
tw2
If you need it. Door Sill Clip
Part #: 001-997-65-35-MBZ
Old Feb 10, 2018 | 08:06 PM
Rovel's Avatar
2007 E63 Amg
Thank You everyone for inputs. With your help, I was able to fix the door sill plates. THANKS!!!
Old Feb 10, 2018 | 10:51 PM
tlambert's Avatar
2005 E55 AMG
Double sided tape? Lol 😁
Old Feb 10, 2018 | 10:54 PM
Rovel's Avatar
2007 E63 Amg
LOL Nope, put the clips back in
Old Feb 10, 2018 | 10:59 PM
tlambert's Avatar
2005 E55 AMG
Good deal. Glad it worked out for you.
Old Feb 11, 2018 | 04:21 AM
mondo's Avatar
Alfa Romeo Giulia Veloce
glad this has been posted. caught mine with the heel of my thong (flip flop for you Americans) and snapped the plastic surrounding the sill plate. going to see if i can get it off and repair it thanks
Old Feb 11, 2018 | 09:25 AM
Rovel's Avatar
2007 E63 Amg
Where are flip flops called thong? LOL It means very different in the US English
Old Feb 11, 2018 | 04:38 PM
Strigoi's Avatar
Thongs was a very common term for them when I was growing up here in CA. I just call them flippity floppities now.
Old Feb 11, 2018 | 08:46 PM
mondo's Avatar
We have those thongs too. The bit under my username should give you a clue where btw...
*fun fact, in New Zealand they call them Jandals
