Intake leak / hesitation
Old Apr 25, 2018 | 12:17 AM
precisionmike's Avatar
2003 C32
Hey All,
I just picked up a 2003 e55 with 140k. Mods include EC ECU tune, DTK TCU tune, 83mm pulley, shorty headers. I get a slight stutter/hick up when I hit the gas hard. I have read that many e55s have this issue, but could not find a solid remedy. No CEL. A reputable source told me it could be an intake leak. Based on the age, mileage and fact that I live in hot/dry AZ, I was thinking of pulling the intakes and S/C and replacing all gaskets. I know it might be excessive, but I want to go through the car and make it is 100%. Your thoughts? TIA, Mike
Old Apr 25, 2018 | 01:53 PM
eFifty5AMG's Avatar
2004 E55
Stock throttle body? Are you doing any logging? You could do a smoke test to check where leaks may be coming from. Replacing all the gaskets would definitely be beneficial & you could take a look at the internal sc bearings/ have them replaced at the same time; at 140k it'd be advisable to proactively replace things before they become bigger issues.
Old Apr 26, 2018 | 12:45 AM
2003 C32
Good advice, I appreciate it. So I pulled the engine cover off and noticed this. I called the PO and asked him about it. Apparently the hose cracked and disintegrated, so he capped it. He mentioned the other end goes somewhere under the blower. So as a result, I am thinking I will pull the blower, replace all gaskets and fix it properly...unless someone has a better idea.
Old Apr 26, 2018 | 01:11 AM
2003 C32
...sorry- stock TB and no data logging just yet.
Old Apr 26, 2018 | 02:12 AM
Style_Front's Avatar
ez-go
Are you certain it's not just a rough supercharger clutch engagement?
Old Apr 26, 2018 | 11:41 PM
2003 C32
Very good question. I will be measuring the gap tonight.
Old Apr 27, 2018 | 05:58 PM
E55Greasemonkey's Avatar
This place is a joke.
Not likely an intake leak. Check your fuel pump for burnt connectors (under the back seat) and the relay in the right rear trunk for a burnt plug.
Old Apr 29, 2018 | 08:36 AM
sexyxe's Avatar
04 E55
I will need to double check to be sure, but I'm 85% confident on mine, that that T valve is not a 4 way on mine. I have removed the SAI so can check the parts box in the morning.
Old Apr 29, 2018 | 09:28 AM
2003 C32
Thanks very much, I appreciate it.
