Belt Slip!
Old Jun 1, 2018 | 11:20 PM
karpetcm's Avatar
2006 E55 AMG
Belt Slip!
Before going into Hp mods ive ordered a superflow pump and split cooling im gonna just do a 83mm or 80mm pulley nothing crazy. After getting my tune done from EC go for a drive and right before it ahifts or as it shifts i hear belt slip. Doesnt happen always just sometimes. So before getting a pulley what is a decent priced pulley tensioner kit and does it actually save 1-2 psi of boost?. Right when it shifts i hear a squeal.
Old Jun 2, 2018 | 12:01 AM
w204_racing's Avatar
C300 sport 2008
https://youtu.be/6lj6xEmP7LE
so quick 😍
Old Jun 4, 2018 | 09:35 AM
MACEDON's Avatar
05 E55, 98 CLK320
That's your clutch engaging, they call it a supercharger chirp.
Remove one of your shims, or life with it.
They do sell belt wrap kits (upd, dtk, creative steel, pick one); this is to battle belt slip at really high RPM.
Tbh, just get a green belt and go from there. I think BWK's are a good way to start ruining your pulleys and bearings, but that's just me.
Old Jun 4, 2018 | 02:16 PM
Creative Steel's Avatar
SPONSOR
AMG's, CTS-V's, SRT's
BWK’s ruining bearings is somebody’s poor excuse for cheap bearings or poor installation of bearings. The tensioner is the only thing that applies force on the bearings. As long as the tensioner is in the same spot there will be no added tension on the belt or bearings.
Old Jun 5, 2018 | 10:52 PM
Das Geld 2's Avatar
SL55, S500
At what point in the video was the belt slip?
Didn't hear it
Old Jun 5, 2018 | 11:00 PM
karpetcm's Avatar
2006 E55 AMG
Didn't hear it
very last second of the vid. You can hear a screech.
Old Jun 5, 2018 | 11:03 PM
Davednconfused's Avatar
2005 E55 AMG
You might just have a belt that is too big.
I run a 185mm crank pulley with a 52' belt - no BWK. No slip whatsoever.
Old Jun 5, 2018 | 11:12 PM
karpetcm's Avatar
2006 E55 AMG
just probably need a new belt. When the car gets warm or hot is when it does it.
Old Jun 7, 2018 | 03:39 PM
Cory @ Weistec's Avatar
PLATINUM SPONSOR
W204 C63 AMG
A good way to battle belt slip is always making sure your belt is in good condition - No cracks, wear points or missing ribs. Easiest way is by buying a new belt! Additionally, you can take it a step further by upgrading the pulleys.
Old Jun 8, 2018 | 02:08 PM
karpetcm's Avatar
2006 E55 AMG
when I swap the pulley ill get the belt and call it a day. Just not sure to go to a 83mm clutch or 80mm clutch. If I wasn't so hesitant on pulling the front bumper and going dual H/E and I would then go with 77. Seeing how much of a pain it was for the body shop to put on my e63 bumper on that passenger side put me off a bit.
Old Jun 9, 2018 | 06:03 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Had this done to my pulley,micro etching
Old Jun 9, 2018 | 01:16 PM
mbmg's Avatar
2004 E55
GripTec from z-industries.com?
Old Jun 9, 2018 | 02:38 PM
cnterline's Avatar
yes
Old Jun 10, 2018 | 04:43 PM
karpetcm's Avatar
2006 E55 AMG
Im hoping i dont go to that extent and hope just changing to a newer belt will do. Will see hopefully soon enough. It might slip more with a smaller pulley crossing my fingers it doesnt slip with a new belt.
