Crank pulley bolt backed out
Old Jul 20, 2018 | 02:09 AM
  #76
1b@damg's Avatar
2005 E55
Almost two hours of cleaning and we have this. On the inside of the oil pan there was some sealant that was much harder material than the silicone, confirmation the sealant from Mercedes must be used.
Old Jul 20, 2018 | 09:38 AM
  #77
tlambert's Avatar
2005 E55 AMG
The Mercedes sealant is harder to clean off.
Looking good!
Old Jul 20, 2018 | 01:03 PM
  #78
95viper's Avatar
2007 cls550
Nice job. I am buying those blades for a future project.
Old Jul 20, 2018 | 06:59 PM
  #79
ItalianJoe1's Avatar
2003 CL 600
Benz actually has a spray to soften/dissolve the OEM sealant, it's a Loctite product. SF7200 to remove and SF7063 to prep after the remover has worked in (it's gotta be 100% neutralized or the new sealant won't cure)
Old Jul 20, 2018 | 10:03 PM
  #80
95viper's Avatar
2007 cls550
After everything was perfectly cleaned, brake cleaner was my last step before applying the MB sealant. This was on timing cover, cam covers and oil pans.
Worked perfectly.
Old Jul 20, 2018 | 10:27 PM
  #81
1b@damg's Avatar
2005 E55
Worked perfectly.
Ive cleaned the surface a few times with brake cleaner, last step I'm thinking I'll clean with soapy water to removed any chemical on the sealing surface. I should have it all back together tonight and let it cure over night. I'll add new oil in the morning.
Old Jul 20, 2018 | 10:28 PM
  #82
95viper's Avatar
2007 cls550
No please!!!
soapy water will leave a residue.
Brake cleaner will leave absolutely nothing.
Old Jul 21, 2018 | 03:22 AM
  #83
1b@damg's Avatar
2005 E55
No please!!!
You are correct good thing i read your post I just cleaned it with brake clean. Thanks!!!
Old Jul 21, 2018 | 03:29 AM
  #84
1b@damg's Avatar
2005 E55
Got the new seal and plate back on and the tranny installed. The tq converter was a pita. I had to line it up first and get a couple bolts started to get the tranny to seat properly.
Old Jul 21, 2018 | 06:53 PM
  #85
1b@damg's Avatar
2005 E55
Got the car all wrapped up today. Took it for a drive so far everything is dry woohoo!!!
Old Jul 21, 2018 | 10:27 PM
  #86
viper04's Avatar
Nice seeing it all together.
Old Jul 23, 2018 | 11:30 PM
  #87
1b@damg's Avatar
2005 E55
Well I hate to report back that there is a small oil leak on the bell housing. It's on the passenger side. I doesn't look like it's from the oil level sensor. Very frustrating especially after how careful I tried to be with everything. Not enough that leaked on the floor while the car sat overnight, but I could see some oil. For now ill have to live with the leak. But at least it's not a puddle like before.
Old Jul 24, 2018 | 02:30 PM
  #88
95viper's Avatar
2007 cls550
The only thing that I can think of is a wrong torque spec or sequence...or maybe that the sealant was applied but took to long to install and hardened up a bit? They gave me 15min working time.
Old Jul 24, 2018 | 02:39 PM
  #89
2003 CL 600
From the picture, there is WAY too much sealant. There is supposed to be a 2mm bead, it has to squish out and not smear everywhere. They can leak with too much there, as it never hardens and the oil pushes it out.
Old Jul 24, 2018 | 09:39 PM
  #90
1b@damg's Avatar
2005 E55
I made sure to get the cover on quickly and took less than 10 minutes but I did not replace the bolts with new ones. After doing some research I'm reading they should be replaced. There's nothing more that bugs me than oil leaks. I'm going to let the weather cool down a bit and go through it again soon.
Old Jul 24, 2018 | 11:21 PM
  #91
95viper's Avatar
2007 cls550
I would be surprised if the bolts caused it although the torque specs could be all jacked up.
Old Jul 25, 2018 | 08:30 AM
  #92
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
The black sealant from the factory disintegrated on my valve cover breathers. The stuff I replaced it with is called 3bond. It's a silicone used for sealing dirt bike center cases. I bought it at the motorcycle shop and it's never failed me in 18 years. Even in high pressure fuel systems
Old Jul 25, 2018 | 09:47 AM
  #93
95viper's Avatar
2007 cls550
The factory sealant is all over your engine so something is up there. Valve covers, cam covers, timing cover, upper and lower oil pans. It works if properly used.
The WIS documentation is completely **** about the length of time it can be exposed, the bead diameter, and torque specs.
Old Jul 25, 2018 | 11:41 AM
  #94
I don't think any part of my motor is completely dry, and everybody's valve covers have leaked somewhere. It's usually the breather covers because there is no gasket...it's all on the silicone. Good chemicals are a beautiful thing. So many times I've used 3bond and the appropriate color loctite on the bolts and never had to think about that job again.
Old Jul 25, 2018 | 10:50 PM
  #95
1b@damg's Avatar
2005 E55
Im going to place the lower engine cover to collect any drops of oil for now lol. The car now has 500 miles since fixing the crank pulley issue and I'm just going to enjoy the car.
Old Jul 26, 2018 | 06:44 AM
  #96
Yeh, I get it. The work on it--- to---driving it ratio is tipped wrong.
Old Jul 26, 2018 | 07:15 AM
  #97
SICAMG's Avatar
2005 e55 AMG
Man you said it !! My car really is never "broke" but it sure is garaged a lot due to "modification" time !!
I'm always tipped wrong....got to get on that problem!!!!! LOL
Old Jan 14, 2019 | 03:15 AM
  #98
hegar817's Avatar
2003 s55
Pulley tool rental
Originally Posted by 1b@damg
I cleaned the crank snout with some sandpaper by hand till it was smoothed. I found a used oem pulley but after reading about them coming apart I'm kicking myself for not buying a new one especially since the used one was 300 buvks.... A new one wouldn't of been much more expensive.
If anyone needs to borrow the tool I made to hold the pulley I can loan it out.
Wondering if you would loan the tool out to me. If you could message when you get a chance.
Hector
