83mm or 80mm Pulley Clutched.
Old Jan 22, 2019 | 11:42 AM
  #101
E55_MvP's Avatar
2005 E55 AMG
Did you ever get the dyno results with the 80mm? I'd like to know how much it adds.
Old Sep 14, 2019 | 11:42 PM
  #102
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
Can anyone chime in on which supercharger pulley is best for a street only car? 83mm or 80mm? I know the 83mm can run the stock belt but what about the 80mm? With an 80mm will anything need to be upgraded and or changed out? Heat exchanger, etc.? Thank you!
Kindest Regards
Old Sep 14, 2019 | 11:47 PM
  #103
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
Originally Posted by nkctb7
Can anyone chime in on which pulley is best for a street only car? 83mm or 80mm? I know the 83mm can run the stock belt but what about the 80mm? With an 80mm will anything need to be upgraded and or changed out? Heat exchanger, etc.? Thank you!
Kindest Regards
There are lots of posts about crank pulleys that are the equivalent of the 80 if you search. Even a stock car can benefit from upgraded cooling
Old Sep 14, 2019 | 11:54 PM
  #104
nkctb7's Avatar
My apologies as I should have specified supercharger pulley and not crank pulley. I have searched and there isn't much info. on an 80mm supercharger pulley. I noticed that VRP no longer sells an 83mm as they appear to have replaced it with an 80mm.
Regards
Old Sep 15, 2019 | 12:23 AM
  #105
carguyshu's Avatar
Reread the thread. It’s clearly stated an 80 supercharger is equivalent to a 172 crank. There are lots of threads on 172 crank.
Old Sep 15, 2019 | 10:19 AM
  #106
oneslow55's Avatar
E55 amg
If the 80 is in a car that's healthy coupled with a nice tune and conditions are good you should make 480 whp easy .It's 'like a 77 without as much heat just not a fan of clutches on pulley for this platforum!
Old Sep 15, 2019 | 10:26 AM
  #107
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
You can run the 80mm without additional modifications, However, I would atleast get a bosch 010 and split cooling kit.
