83mm or 80mm Pulley Clutched.
Now i got the headers out of the way because that always comes up, im kinda torn not sure wether i should do a 83mm pulley or 80. Dont want to go too crazy on pulley size because a 77 will require way more then the cooling mods i have plus injectors to be safe. My goal is to be about 460-470rwhp as we speak im about 434rwhp. For people who are using a phone i have a Superflow IC Pump and VRP Secondary H/E. I havent seen any threads on 80mm pullies and peoples experience with it.
As for HP gains with an 82mm TB you would be looking at 20-30HP as seems to be the consensus on the forum.
As for power here is a nice little formula for hp gain per mm of pulley size lost. https://mbworld.org/forums/w211-amg/...ize-boost.html
By shorty headers, hopefully you mean mid length? Shorties (keep stock downpipes with huge restriction + cats) are a wasted modification on these engines.
I think shorties can yield 12 wheel but give you header tick which personally i dont like the sound of but woth mid or long its worth the tick for the power gainz. Ill let you know if lsd is worth it shortly. Just gotta get back from holiday to install..
