Need a valve cover gasket
I just noticed that my drivers side valve cover is leaking and even though its not causing an oil spot on the floor, I can see that's its leaking leaving black all over the cover. Ive also had to add about a bottle of oil every few weeks (I drive a lot) so I think its time to do the change.....my "Check engine" light came on this morning too so Im hoping this is why.....Anyway I have a few questions:
1. Do I have to change out the gasket maker seals on both covers for the top parts if they are not leaking?
2. Where is the best place to get a valve cover gasket set? I don't want to get some off brand and be in the same situation in a few months because I decided to get a cheap aftermarket.
I have already found the DIY's on here for the change so Im confident that I can do it but I just want to make sure I get a good quality part.
Thanks everyone.
Also leaking valve cover gaskets wouldn't set off a check engine light
Reviews dont appear to be great from the two reviews, but I very very carefully installed mine to the letter 1 year ago, and thus far, no leaks at all.
Key with valve cover gaskets and with using the sealants: perfection is an absolute must. Its a job that cant be rushed at all.
https://www.fcpeuro.com/products/mer...it-oem-m113016
https://www.bimmerforums.com/forum/s...ead-gasket-kit
https://mbworld.org/forums/clk-class...r-gaskets.html
https://mbworld.org/forums/mercedes-...they-leak.html
https://mbworld.org/forums/clk-class...i-replace.html
https://mbworld.org/forums/c-class-w...asket-not.html
https://mbworld.org/forums/clk-class...g-burning.html
These are just the first few I bothered to link. Ctrl+F "Victor" if you want to skip the exact part where the complaints are in each one. Some of these people are very highly regarded techs, mechanics or people like bbirdwell.
That said, the points made at that time appear to be valid. And I have no stock in VR gaskets but do know that FCP's kit sent to me (which contained VR gaskets) fixed my issue. The job (on the CLK55) wasnt hard so if (heaven forbid) the gaskets leak again anytime soon, I'll most likely go with OEM benz, depending on price.
Anyway the difference is $6 between VR and oem. People can make up their own mind where they want to save money. I remember it being a totally crap job getting the covers clean and old sealant off, no way I would want to be going back in there again. But yes hopefully they have improved their design recently.
