Weird problem on every morning
Old Feb 12, 2019 | 12:55 PM
mAMG's Avatar
SL55 2003
Hello All,
Everyday in the morning, I switch the Engine on and put the gear in drive. Once the car starts moving and reaches the 2000 RPM, it drops to 1000 RPM immediately, as if I took my leg off the throttle pedal.
This happens only the 2nd gear or 3rd (Car is always on "C" mode). Once the car is driven/warmed for 5-10 mins it never happens.
I've done a quick test through Star SDS, it showed that the "B28" Pressure sensor is stored (Code: P2007-008).
Removed the sensor (A004 153 33 28), replaced it with the new one which is (A006 153 98 28). However, the problem still exists.
At this moment I don't really know what is cause of the problem. Hope you guys help me sort it out.
Old Feb 13, 2019 | 07:41 PM
Fantomas's Avatar
2006 ML350, 2005 C55, 2004 E55
It sounds like you're describing the TCC solenoid issue. When the car is cold it starts out in 1st gear even in C mode, the TCC solenoid engages abruptly and only when cold. Once warmed up this goes away.
https://mbworld.org/forums/c32-amg-c...em-solved.html
Old Feb 14, 2019 | 11:46 AM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Yep I second the TCC. Replace it along with plug connector and conductor plate, filter and new ATF and you should be good as new.
Old Feb 22, 2019 | 06:00 PM
mAMG's Avatar
SL55 2003
Alright then, I'll have to change it sometime .
Is it fine if I drive the car like that for a while ?
​​​​​​The thing is, its just a matter of weeks and the temperatures here is going to skyrocket again, so the issue won't be happening.
Old Feb 24, 2019 | 02:23 PM
N_Rob's Avatar
2008 BMW M5, 2004 E55 AMG (RIP)
Yes you should be fine to drive it like that for the time being, I doubt it’s putting that much extra (if any) strain on the tc. I have the same issue that started when the temperatures dropped a lot back in early January and haven’t replaced it yet, though mine doesn’t drop as many rpm as yours.
Old Feb 25, 2019 | 08:29 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I read through that thread up into the 70's and one thing I didn't see... shouldn't a new conductor plate come with all the solenoids? I didn't realize you had to, or could replace them separately.
Old Feb 25, 2019 | 10:42 AM
Solenoids are all separate, the conductor plate is just what supplies them with power. Solenoid failure is rare, especially shift solenoids, but for about $60 the TCC solenoid is a no brainer while you're in there.
Old Feb 26, 2019 | 02:42 AM
PieRat's Avatar
CLS55
I assume this solenoid is the most prone to failure being for the torque converter?
Old Mar 20, 2019 | 09:42 AM
mAMG's Avatar
SL55 2003
B28 Pressure sensor error still exists, with 2 more errors.
Any ideas ?
Could it be the installed item is wrong part number ?
Old Apr 29, 2019 | 08:54 PM
mAMG's Avatar
SL55 2003
Well, I believe i got the infamous hiccup issue that usually happens on larger throttle bodies, although my car is stock.
It usually happens after a highway drive, once I slow down, the car starts to shake/surges.
Works fine after a restart ...
Old Apr 29, 2019 | 09:05 PM
I'd check all vacuum connectors near the back of the supercharger, especially since you probably had some stretched to get to that darn MAP sensor (ask me how I know).
There's the brake booster plug/plunger and then a metal pipe underneath that, both on the drivers side, that are prone to leaks as well.
My hiccup has remained but I finally got a code for the bypass actuator motor, which greatly explains a loss in power between shifts and at random times when it should be closed but isn't.
Just pulled the supercharger tonight, what a chore, hopefully back together soon...
Old Apr 29, 2019 | 09:30 PM
N_Rob's Avatar
This. There is a vacuum line that attaches to the back of the supercharger on the driver's side (if you have a LHD car). I had this issue too after redoing my valve cover gaskets and I didn't put the metal part of the line back in correctly, it felt like it was in place but was not. Remove the driver's side surge tank and use a handheld mirror to get a better view of the grommet.
Old May 1, 2019 | 02:45 PM
mAMG's Avatar
SL55 2003
They are all connected ...
