E55 amg power gains
Old Mar 14, 2019 | 06:33 AM
55AMG.'s Avatar
2005 e55 amg
E55 amg power gains
Just had My 2005 e55 amg with 68,000kms in the shop for pulley upgrade and custom tune went from 245kw to 292kw . What do you guys reckon is that about normal only mods are pulley upgrade tune and cats removed ??
Old Mar 14, 2019 | 09:54 AM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
Well doing the kw to hp conversion looks like your making round 391 rwhp with the tune pulley an cats removed .... if i did my conversion right. If so thats extremely low these cars make over 400 to the wheels stock. What kind of dyno?? Are you sure the intercooler pump working? That would explain such a low number for sure.
Old Mar 14, 2019 | 10:17 AM
55AMG.'s Avatar
2005 e55 amg
This is my dyno result ??
Old Mar 14, 2019 | 04:18 PM
tw2's Avatar
tw2
Which pulley size? Which tune? Is the intercooler pump original?
Old Mar 14, 2019 | 06:14 PM
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
i second with the member who said its low, maybe your ic pump is failing you should be closer to 440whp or higher!
Old Mar 17, 2019 | 07:59 AM
55AMG.'s Avatar
2005 e55 amg
83mm eurocharged pulley, original pump, custom tune from torqueperformance
Old Mar 17, 2019 | 08:00 AM
55AMG.'s Avatar
2005 e55 amg
have ordered new heat exchanger and Bosch 010 pump so should help
Old Mar 17, 2019 | 12:33 PM
AMG__POWER's Avatar
definitely should help, I put down around 500whp with similar mods plus kleeman header, belt wrap and some more cooling mods
Old Mar 17, 2019 | 02:48 PM
tw2's Avatar
tw2
I have all the same mods. I should drive up to Auckland sometime and get dyno'd.
Old Mar 17, 2019 | 05:30 PM
AMG__POWER's Avatar
Old Mar 17, 2019 | 05:33 PM
55AMG.'s Avatar
2005 e55 amg
where about are you didn’t think I’d find anyone from nz on here. Yea also getting belt wrap kit and some mid length headers ? What mods have you done ??
Old Mar 17, 2019 | 11:42 PM
tw2's Avatar
tw2
I'm in Hamilton, so is kiwibenz. One in whangarei, austingir in Rotorua, pierat in chch and a few others around just off the top of my head. No to belt wrap, I haven't got any issues I am aware of. If I had a smaller pulley I might consider it. I preferred not to add yet another pulley to the system but that's just me.
I might get longtubes, if so I will ask austingir nicely to make me some, he does amazing welding. In NZ it is not worth the money for mids. By the time you import, weld and fit them, you are almost in longtube money.
My mods are listed below, 83mm, 010, PLM etc.
Old Mar 18, 2019 | 06:14 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Wow, you have low miles on that beast!! Pulleys (supercharger and idlers), cooling mods , Belt wrap kit, UPD cold air intake, adjustable rear toe and camber arm set, headers .
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
