Ball Joint Removal Without Damage to Boot
Old Sep 29, 2019 | 07:44 PM
Rallyboy383's Avatar
2004 E55
I need to replace the front lower control arms on my 2004 E55 AMG. I already replaced the lower ball joints about 25000 miles ago. Is there any way possible to seperate the lower ball joint from the lower control arm without damaging the ball joint boot? The ball joint separator that I have will damage the boot because it is not quite wide enough. Is there one that is made with a wider jaw opening that would work for my purpose? Any recommendations?
Old Sep 29, 2019 | 11:27 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Front lower control arm ball joints are not replaceable. The front lower control arms are aluminum; removing and reinstalling the ball joints will result in excess play, i.e. loose fit. Your front lower control arm suffered what is referred to as "infant mortality" with an early failure. Just bite the bullet, replace the control arm, and realign the toe of the front wheels. I feel your pain as I am replacing both lower front control arms after just 72,000 miles which I regard as ridiculous.
Old Sep 30, 2019 | 03:11 AM
AMGPilot's Avatar
2004 E55
That's not correct at all. you can replace the lower ball joint, I have and there is no play or weakening of the control arm
Old Sep 30, 2019 | 06:36 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Control arms, thrust arms. Thrust arms are the aluminum ones and can be replaced without taking anything else apart. I ground the tips off my ball joint fork and pounded from the inside, aiming for the backing plate. the tips would have dented the backing plate if I left them on.
Old Sep 30, 2019 | 11:07 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I was referring to the aluminum thrust arms. From the OP's post, when he said *front* lower control arms, I assumed he means the thrust arms; those are called "strut rods" in the parts diagram and are listed as "control arms" on the Pelican Parts website. Ball joints are available for the rear lower control arm (the steel one). From the below parts diagram, a separate ball joint is not available for the aluminum arm. So, here's a handy picture of the front end to which folks can refer.
FWIW, I was going to replace the "strut rods" this past weekend but realized I did not have the proper bushing bolts; I installed KMac bushings 72,000 miles ago and they use a "D" bolt". So another delay. sigh....
Old Sep 30, 2019 | 01:21 PM
anomadtoo's Avatar
09 E63
I too have to replace my lower control arms; would you all recommend this? https://www.fcpeuro.com/products/mer...mforder-516478
anything else needed or recommended? I appreciate it!
Old Sep 30, 2019 | 02:25 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
If it is just the thrust arms (aka strut rods), yes, that's a good combo. I don't know how much you know about how the bolt insertion position affects the alignment but here is a link to the placement (inner, center, outer):
https://mbworld.org/forums/e-class-w...ml#post7514643
Old Oct 1, 2019 | 08:08 AM
That's a good price too... for a pair of strut thrust torque rod control arm thingies.
Old Oct 1, 2019 | 01:35 PM
anomadtoo's Avatar
09 E63
exactly, haha (and free lifetime warranty)
