Installing my PLM Heat Exhanger and Bosch 010 pump. Any tips?
If you have a clear tube to run coolant back it helps to watch air bubbles getting less, as well as squeezing one of the hoses below the bleeder to get a better flow.
PLM mounts up great.
Good luck!
https://mbworld.org/forums/w211-amg/...-pictures.html
Excellent write up and the best part...The pictures! I used your idea of jumping the pump relay in the trunk and it worked perfect. Took about ten-15 minutes of constant running to bleed out the air bubbles. I used 5/8 clear tubing.
E63 bumper getting painted tonight. Got the system bled last night via jumping the relay in the truck and a 5/8" clear hose. Should the pump be running when i remove the hose from the bleed nipple and re-install the cap? or does it not matter?
Now the only question is what size supercharger pulley do I order
