P207c supercharger mecanical fault PO660
Old Nov 23, 2019 | 09:29 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
Posting for a buddy....Excuse my sp.)
05 E55 intake, throttle body, 77mm pulley, BW, 3k stall T converter, LT's, LSD, meth kit (not currently used) aux cooler, EC tune.
Car has been running great until....
Car starts and idles fine, drives fine up to 1/2 - 3/4 throttle, until you romp on it. Then it kills the SC and goes into limp mode with an ESP light.
So Far..
Recirculating Air Flap responds with SDS.
Elctromag SC clutch also responds to SDS
ECU is clean.
Tune was re-applied.
Still to check.....Pedal switch and fuel pressure. Any other ideas?
Old Nov 24, 2019 | 07:35 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Could a bad coolant temp sensor cause this?
Old Nov 24, 2019 | 10:21 AM
Pmarino's Avatar
Yes possibly, that will go on the too do list, thanks!
As well as coolant pump relay.
Old Nov 24, 2019 | 05:58 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Mine did this and was the accelerator pedal. Restart and drive and it’s perfect. No issues unless you go WOT.
Old Nov 25, 2019 | 05:56 AM
I meant the engine coolant sensor.
I had a pedal fail too, but mine messed up at the very beginning of it's travel.
Old Nov 25, 2019 | 11:57 AM
Pmarino's Avatar
Understood, maybe that's why the high negative value (-279.51v)?
Any idea what (ADC) stands for?
Old Nov 26, 2019 | 06:43 AM
Absolutely don't cuss! Sorry, not a clue.
Old Nov 26, 2019 | 07:09 AM
hayseed's Avatar
04 e55
hopefully something simple like the Y pipe/snorkel has a split in it the appears when high volume sucking through, but it sounds like Recirculating Air Flap not working under load (i know you tested with STAR) ,,, does it fall on its face if you disconnect the SC belt and drive it ? also you can tape a fuel presure gauge to your windshiled connected to the fuel rail and do some pull to see if presure maintains at high RPM ? just tossing out some ideas ....
Old Nov 26, 2019 | 11:57 AM
Pmarino's Avatar
[QUOTE=hayseed;7912825]hopefully something simple like the Y pipe/snorkel has a split in it the appears when high volume sucking through, but it sounds like Recirculating Air Flap not working under load (i know you tested with STAR) ,,, does it fall on its face if you disconnect the SC belt and drive it ? also you can tape a fuel presure gauge to your windshiled connected to the fuel rail and do some pull to see if presure maintains at high RPM ? just tossing out some ideas .... [/QUOTE
Thanks hayseed, exactly what I'm looking for....ideas!
I did hear a an intake sound when the car was rev'ed standing still. Sounded like a leak where the front drivers snorkel of the FTP intake meets the filter. But that was before the air filter, so I didn't think it would register as unmetered air? Waiting to run real time fuel pressures
Great idea about disconnecting the SC
Old Oct 4, 2021 | 02:36 PM
e55andrew's Avatar
2006 E55
Having an identical issue with my 06 with similar mods, what was the final verdict?
Old Oct 5, 2021 | 01:18 AM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Have you done an overnight battery unplug? Always a first step. Otherwise we need data on the fault code, freeze frame values etc. Then more testing in STAR, smoke test etc to narrow down the cause.
Old Oct 5, 2021 | 10:43 AM
Pmarino's Avatar
Turned out to be the intercooler pump!
Old Oct 5, 2021 | 12:45 PM
e55andrew's Avatar
2006 E55
Turns out we had an intake coupler that was sucking shut under WOT
