Another fuel pump story + no starting
Fast forward to a successful a/c job and the car won’t start. I filled it to the brim just yesterday and had no issues. So I first checked the pump relays which look perfect, then moved into the rear seat. The driver’s side pump has fuel pooled on top.
My question now is: could the two problems be related? The only reason I am hesitant to believe so is because the car runs flawlessly after startup.
Any ideas? I am at my wits end with this thing after just finishing my last job, just to get in and have the car fail to start. Worst feeling in the world.
Nothing visually looks off about the pump or connections but of course the tank is filled to the brim and I can’t pull the housing out without getting gas everywhere. Any ideas on easily siphoning a few gallons out?
I also cranked the car several times and then checked the schrader valve on the passenger side fuel rail and there was nothing. So I’m guessing it’s a pump/sender issue. Although I’m not sure I understand what the sender specifically is.
I kept a spare top hat for the fuel pumps but sold the other top hat to another member on the forum.
FWIW, I do not believe the two A/C and no-start are related. Are you getting fuel pressure to the rail? Could you have damaged a harness while under the hood working on the A/C? Any moisture in the front SAM or ECU?
I don’t think the A/C is related and I don’t believe I damaged anything or got fluid into the SAM or ECU ( although my SAM does not have the rubber cover you recommended - shame on me).
My starting issue has been intermittent for almost a year, with the car coughing to life. This leads me to believe it is a fueling problem. I have what I believe is an early 2005 MY (summer 2004 production) but it looks like it has the later relays you have previously described that came on later cars.
I suppose it is most likely I have had a leaking fuel pump housing for some time now, and the starting issue is unrelated however it seems it must be a pump issue also. With the back seat cover off and the access covers off, I heard nothing when I cranked the car over. I assumed I would hear them but maybe not?
If it is just the seal on the pressure sensor, see this post for replacement of the sensor only:
https://mbworld.org/forums/e-class-w...ml#post8151442
Alternatively, the fuel hose clamp did not seal the connection or fuel is leaking around the pins for the float signals (unlikely but possible). If the later, clean and use a *very little* bit of epoxy around the pins; let cure prior to reinstalling the connector.
If you have two relays in the trunk, only one is for the fuel pumps on the model year 2005; the other relay power the secondary air injection pump located under the driver's side front bumper. Model year 2006 have three relays in the trunk; two for fuel, one for air.
edit: stupid question obviously, I can siphon with a pump. Will report back with findings when I can actually pull everything out!
EDIT: Never mind; found some better photos and the top hats on that version appear to be significantly taller and molded into the body of the filter holder. The E55 version has some serious ribbing added for the additional pressure encountered.See photo for how to remove top hat. Right line is where it is locked and you have to depress the tab to rotate the top hat; left line is unlocked and you can remove the top hat. I had to use a vise (carefully!) and a strap wrench to remove the top hat. Reassembly I recommend some sort of lube on the O-ring to ease assembly.
