Where to reset tcu hard limp mode in West LA
Old Oct 3, 2020 | 04:06 PM
Ramodeys's Avatar
W211 E55
2006 E55, I had an issue with my transmission shifting into neutral randomly which threw the car into limp mode giving speed sensor codes. I swapped out the transmission conductor plate and the limp mode still remains since it needs to be reset with star or an equivalent device. I just have obd and can't read the tcu, but I assume the speed sensor codes are still stored on the tcu preventing it from exiting limp mode from what I read online. I have called a whole bunch of places in my area and they say that this can't be done and the whole trans conductor plate needs to be reprogrammed which I seriously doubt since it is just a circuit board and doesn't store information. One place even said that it is a security part and he was surprised they sold them to people. None of the shops I wanted to even touch the car.
So my question is, where can I go to get the codes deleted so the car can exit limp mode?
Is there anything else that needs to be done besides clearing the tcu codes to exit limp mode?
Old Oct 3, 2020 | 06:43 PM
PieRat's Avatar
CLS55
just get code cleared with,star or maybe a good general deep scan tool can do too..they talking e63 trans for coding of conductor plate...
Old Oct 4, 2020 | 03:42 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
im in the OC, pm
Old Oct 4, 2020 | 02:28 PM
Worth the wait's Avatar
2006 E55
Have you tried unplugging the batteries for a while?
Old Oct 4, 2020 | 02:50 PM
Ramodeys's Avatar
W211 E55
Yea I tried that as well as clear with obd but it still won't come out of limp mode. From what I read, it is in hard limp mode and the only way is with star or an equivalent system
Old Oct 4, 2020 | 02:54 PM
Ramodeys's Avatar
W211 E55
I will check with a few more places and specify that its the 722.6, they must think its the 7 speed in that case.
Old Oct 4, 2020 | 07:56 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
did you code the conductor plate to your vehicle? they need to be married. you'll need the correct system to do this. along with this, the technician should clear any codes with appropriate tool.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Oct 6, 2020 | 04:14 PM
SICAMG's Avatar
2005 e55 AMG
You do not need to code conductor plate. I have replaced many on the 722.6 and have never done it...they are just plug and play so to speak.
The OP's problem lies some where else .
Old Oct 6, 2020 | 06:27 PM
PieRat's Avatar
CLS55
His car is (via the trans) in hard limp mode. Fixing the problem won't get the car out of limp mode alone, he also needs to get the transmission codes reset. I think since has replaced the conductor plate he can reset the code and get back on the road!
I experienced the same when i replaced my valvebody and conductor plate. the plate got damaged in shipping and the speed sensor was not operating correctly.
Old Oct 6, 2020 | 06:51 PM
SICAMG's Avatar
2005 e55 AMG
There has to be somebody that has the correct computer to get in there and clear everything !
Old Oct 7, 2020 | 07:13 PM
Slider's Avatar
04 E55 AMG
I used a guy in Palm Springs to turn the annoying SOS off, but that's 1.5 hours away.
Old Oct 7, 2020 | 07:52 PM
Ramodeys's Avatar
W211 E55
another user on here offered to clear it with their scanner which I will do but now the car has a battery/alternator issue(red message on dash) so I will have to deal with that first. Strange since I changed out the battery and alternator a few months back.
Old Oct 7, 2020 | 07:57 PM
PieRat's Avatar
CLS55
check the small battery under the cabin filter in the engine bay it probably kaput
Old Oct 7, 2020 | 07:59 PM
Ramodeys's Avatar
W211 E55
didn’t even consider that, will give it a check.
Old Oct 7, 2020 | 11:01 PM
Slider's Avatar
04 E55 AMG
Probably just the auxiliary battery.
Old Oct 9, 2020 | 08:28 PM
Ramodeys's Avatar
W211 E55
Got the rear and aux battery fully charged (still waiting on the new aux battery), but now it won't crank. Relay and fuse are good. Just one thing after another with this car. I'm gonna wait for the aux battery to come, but I doubt that has anything to do with the starter. The starter might just be dead.
Old Oct 9, 2020 | 09:47 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
<sigh> Install relay switch in starter relay location in the front SAM. Turn ignition key to position one. Flip relay switch to on. Starter turns engine over, starter is good, problem is before the relay (key, EIS, ME). If you flip switch to on, starter does nothing, starter is bad.
Start simple and then work your way up.
Search, search, search!
You are not the first to deal with this. Regard it as a learning experience.
Old Oct 11, 2020 | 07:52 PM
OnlyGerman's Avatar
Too many german broads
Not for the E55 trans....
Old Feb 1, 2025 | 02:37 AM
Joey2023's Avatar
e350
