Broke it real good for sure
One time when racing I tripped the lights at 9,000 rpm !!! Being a Chevy I just didn't care and had more fun then any car I ever had.
The transmission is really holding me back as well and an 8HP would do wonders but that would really be a project.
Having a real hard time tuning on the street as the traction control is pulling all the timing and then shutting the throttle closed 60% according to the data logger at 110-120mph with unbelievable tire spin up top that I have never experienced before. Crazy torque !! Any temperatures below 60 degrees and no sun on the road for tire heat are useless and even my nitrous controller set on 2 second ramp up doesn't help when its all in at 100%
So horsepower should be at 800 to the tires and a little over 900 flywheel and this should pick up at least 4mph by how strong the car pulls now so only time will tell I guess.
Focused on the driveshaft right now. Have had some bad experiences with damaged drive shafts in other cars and don't know what the limit is of our shafts especially with the 3.06 gears I have. So instead of spending 2,500-3,000.00 for a custom shaft, I have decided to have it Cryogenic treated and also replace the soft center section bracket with the VRP setup and the harder bushings deal to keep things nice and stable. For sure a cheaper route and since I know of no one that ever broke a shaft I should pretty safe doing it this way, plus already have the drive shaft safety loop installed.
So my 82mm throttle body always would throw idle speed codes and others like p0505,p0507,p1580 and so on. I would just clear the code only because I couldn't stand seeing the MIL light on but car always ran perfect either way. So when I went to the Helcat 92mm like was raved about and told it had no issues,it would throw idle air speed P0505 and 202A air leak detected. Now,yet again,the car always ran perfect with the light on so this was no big deal but...come emission testing time, this was an issue for sure. So after spraying a few gallons of carb cleaner !! on every gasket while engine running and smoke testing this engine for 20 min. straight pressureizing the engine intake system many many times,there is no leak to be found and the light would come on within 15-20 miles. This was not good because I could not even set my monitors to even go and get the test done so I was kinda screwed a bit with this. So I decided to install my old 78mm throttle body,or 80 as it's called, back on with my adapter set up I made and talked about a few posts back and bingo, no light and all monitors set VERY quickly. The Hellcat in no way would allow the monitors to come close to setting green unless I would drive almost 70 miles and again by that time the MIL light was on long before the 70 miles.Why ?? I tested this so many times I was sick of waisting good race fuel !!
So what I did was put the 80mm on,drove the car,set the monitors quickly,pulled off the 80,put on the 92 ,did not do any reset at all,just put it on, and all was good for almost a WEEK of driving. But I do have a pending p0505 code that will probably come up soon but regardless I have plenty of time in between the monitors setting and the MIL coming on so I'm good with that and can roll right threw the test no problem.
It's almost like I tricked the ECU into thinking the throttle body was smaller and and is why it took a long time for it to see this and decide to throw a generic "leak" code for what ever reason. Could my 92 Hellcat be bad or maybe just a tiny little bit out of range to make the ECU have a small fit over it ? All the testing I have done shows TPS signals and O-2 readings and idle rpm to be right where they should be.I would hate to spend another 300.00 on another 92 for the same results. Plus they are real hard to find new these days from Dodge and VRP want's 500.00 for one.
My rant is over........
Keeps throwing a idle air speed codes,small leak. Possible internal leak past the butter fly shaft but smoke test didn't show it.
So glad I made the adapter plate in case something like this happened LOL
But as I’ve said before I’m not mechanic, I’m just a body man. lol.
It for the bigger and really big ,93mm and up throttle body's. This has been a real pain for our platform for many many years with no real "blanket" fix.
