electrical fire damage E55 62k miles
I was able to get out of the car ok and use a fire extinguisher I have in the trunk. But it has burned the passenger footwell, dashboard and headliner from passenger side to the center console. Car was baby and driven couple time a month only has 62k miles.
My question for anyone who has rebuilt or swap part inside the e55 amg if I plan to repair it.
1. Will the wire harness from any w211 say e320,e350,e500 will work on the E55? Just the wiring part from the center dash to the passenger dash.
2. Edge of the black box TCU module (not sure) was melt/burn will I need another e55 amg TCU or any w211 TCU can be coded to work, which will cost less?
3. I plan to repair or part out the car. From the picture below will 4-5k can repair it? I don't have star laptop, just a normal bluetooth OBDII reader and can turn wrench.
Thank for any input and advise.
burn from passenger dashboard to center, driver side is fine.
the expose circuit board box is the TCU correct? The metal cover module box seem fine.
part of the passenger footwell wiring burn.
passenger dashboard wiring harness burn
air filter box burn, engine and transmisson is fine
aux battery and wiring seem fine
You will need a complete donner dash, all wiring and I mean all , seats, windshield, modules the list goes on and on. Real sorry but it's done. Best to find another that maybe needs a drive train and swap over.
I agree with SICAMG. I’m sure it could be fixed but you would need a lot to fix it. Then once it was repaired if you started having electrical issues chasing the problems might be a nightmare.
Might be better to find another car and use what you can from yours.
been searching but have not see any e55 car with engine/trans problem for sale. Can anyone confirm the partial burn black box module that show the circuit board is the TCU?
Just in case I do find a donor/salvage w211 non amg car will the whole front wiring harness and module and work with the e55 amg car? There plenty of crashed w211 e320/e350/e500 .
The whole front dashboard and HVAC and accessory stuff can stay missing/remove as weight saving. Is it possible with Xentry or Star to disable on the ecu all the module that was burn up so it can start and drive?
Logically and financial of me say a high millage w211 step down to e500/550 around 5k is my right choice.
STILL looking for a good body and interior 03-06 e55 amg car for part swap. 2nd option is 03-06 e55 amg with high millage, non running dead engine/trans, and accident car.
pm me thanks.
You can't leave the dash out for weight savings....this is by far the worst train of thought.
Look for another 55 that has a popped engine , get it cheap, swap over drive train. Done.
My best option like you said buy another 55 with bad engine but that pretty rare through since m113k 55 engine mostly bulletproof. But I will keep looking, maybe I get lucky.
Or is this one of those very rare anomalies?
I have 2 W211 cars and am more than willing to swap out a blower motor to prevent this from ever happening to me.
I was expecting the common stuff pano roof motor, the air supension, trans conductor plate/plug...
Maybe by babying the car and not driving often enough ( to keep low millage) might have advance the blower motor/resister issue it's 16 year old if it still original.
Fcpeuro has video and kit replacement the blower motor for w211 with lifetime warranty https://www.fcpeuro.com/Mercedes~Ben.../Blower-Motor/
