Hood ornament removal question????
Old Sep 20, 2004 | 09:05 PM
eagleeye's Avatar
07 ML63; 05 E55 (sold)
This is a pic of underneath the hood ornament. How do you remove it? Do you need a special tool? Does the part denoted by the arrow screw out or come out some other way?????
Attached Thumbnails Hood ornament removal question????-underside-hood-orn.jpg
Old Sep 20, 2004 | 09:23 PM
t-bone's Avatar
2004 E55
grab the base that you have in your picture and twist it counterclockwise a quarter turn. i think it's counterclockwise, i don't remember exactly which way. once you do, it will pop out from the top very easily.
Old Sep 20, 2004 | 09:28 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
When looking up under the hood, hold the star and use some pliers to grab one of the "c" shaped fins to do a 1/4 turn counterclockwise. ..then from the top of the hood, carefully lift the star up and out so you don't scratch the hood.
Old Sep 20, 2004 | 09:34 PM
M5KILLR's Avatar
first you need an air chisel, a 1/2 drill with an easy out drill bit, a large hammer, duct tape... j/k had the same question then i found out how easy it was. what are you putting in there?
Old Sep 20, 2004 | 09:57 PM
eagleeye's Avatar
Peter B: humerous. This board could use a little more levity.
Old Sep 20, 2004 | 11:37 PM
eagleeye's Avatar
Thanks guys. Its in and perfect!
Old Sep 21, 2004 | 07:07 PM
M5KILLR's Avatar
so post a pic!!!
Old Sep 21, 2004 | 09:26 PM
tjcMBE55AMG's Avatar
2002 MB E55 AMG
Damn ... I used a Sawzall, didn't know about the air chisel.
Thank God for oversize 'goof' plates!
TJC
