Gas and brake pedals
Old Oct 19, 2004 | 05:06 AM
Pat's Avatar
Pat
W211 E63 T
Does anyone know if those oval studded pedals in the new SL will fit a W210 E55? If yes, does anyone have the parts number as well?
Many thanks in advance.
Patrick
2000 E55 T White
Old Oct 19, 2004 | 09:47 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Hi Pat, sure they fit, here are mine. I am using the E-Brake pad with oval studs from the R230 SL and the Gas and Brake pads with round studs from the SLK R170. The SLK pads are much cheaper than the SL pads, but the SLK does not have a foot E-Brake. You can now get all three with round studs from the 2005 C-Class Sport Sedans.
Part Numbers (Of coure prices may have gone up):
R170 ACCELERATOR PEDAL (170-300-00-04) $20.83
R170 BRAKE PEDAL PAD (170-290-01-82) $19.60
R230 E-BRAKE PEDAL PAD (230-430-00-84) $9.80
Old Oct 19, 2004 | 12:54 PM
Pat's Avatar
Pat
W211 E63 T
Many thanks for your info.
Pat
Old Oct 19, 2004 | 01:30 PM
Ttsakai's Avatar
E55 Kev,
Could you shed some light on how the pedals are installed. Is it a straight remove/replace scenario? Or do these pedal pads get placed on the existing pedals? Etc. ...
Installation details would be greatly appreciated.
Thanks,
Old Oct 19, 2004 | 04:29 PM
E55 KEV's Avatar
Veteran: Air Force
If you use the SLK piece it is simple. I believe the C-Class and SL-Class piece require more work.
The E-Brake and Brake Pedal pads just slip on after you remove the OEM rubber pads. The Brake pedal takes a little muscle to get on.
The Gas Pedal is simple - just remove 2 plastic bolts on the floor and push out a pin at the top to remove the OEM pedal and then replace the entire new pedal piece.
Old Oct 19, 2004 | 07:20 PM
TCM's Avatar
TCM
2001 BMW M5
This is a great upgrade to spruce up the interior in the E55. I found that replacing the entire accelerator unit with the SL55 causes the revs to rise due to the throttle by wire. So your best bet is to just slide the SL55 pedal cover over the E55 unit (after sliding off the stock plastic cover). The brake and emergency brake pedals are quite easy to change besides for a possible pinched hand.
Old Nov 9, 2005 | 02:43 PM
E55 KEV's Avatar
Veteran: Air Force
Old Feb 22, 2006 | 09:15 PM
hydeaway's Avatar
996TT
I could not figure out how to remove the pedal . Does anyone have any detailed info on how to do it. Thanks.
Old Feb 23, 2006 | 12:17 PM
E55 KEV's Avatar
Veteran: Air Force
Which one? All of them?
Old Feb 23, 2006 | 02:49 PM
hydeaway's Avatar
996TT
E55kev - I had problem on how to remove the gas pedal but i actually figured it out late last night. Im just not good on these kind of things.
