2005 E55 Amg cyl 8 misfire and smoke only out of left rear pipe
Old Mar 21, 2023 | 05:30 PM
BMWLOL1's Avatar
E55 amg
I have a 2005 e55 AMG w 70k on it has 70mm clutched vrp pulley long tube headers. Car was running fine no issues then misfire code came for cyl 8 replaced plugs and coils car is still misfiring and has smoking only out of the left rear tail pipe. Not smoke related to bad head gasket this is smoke from burning engine oil. Has anyone had experience w this before???
Old Mar 21, 2023 | 05:46 PM
BMW Owner's Avatar
e55 AMG
70mm - holy mother of torches!
Did you replace the wires?
Check compression...
Old Mar 21, 2023 | 06:14 PM
BMWLOL1's Avatar
E55 amg
Haven’t checked comp yet. Wores I didn’t change yet but couldn’t see that causing it to smoke out of the tail pipe.
Old Mar 21, 2023 | 09:22 PM
SICAMG's Avatar
2005 e55 AMG
Sounds like the good ole cylinder eight is dead. Hopefully not .......
Old Mar 21, 2023 | 10:22 PM
BMWLOL1's Avatar
E55 amg
im really hoping your wrong with that. But I’m kinda afraid that’s correct due to the smoke that’s pumping out of the left rear pipe only. I’m doing a compression test on it in the morning hoping for the best.
Old Mar 22, 2023 | 08:06 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Fingers crossed indeed
Old Mar 22, 2023 | 03:17 PM
BMWLOL1's Avatar
E55 amg
Well I did the compression test on cyl 8 and it has 30psi 😵‍💫😵‍💫😵‍💫 guess I’m gonna let this thing sit for a while and figure out my other cars.
Old Mar 22, 2023 | 03:55 PM
Damn RIP
Old Mar 22, 2023 | 08:29 PM
SICAMG's Avatar
2005 e55 AMG
Pull it out and tear into it to see what it needs.... it might be an easy fix.
