Preferred pulley setup for daily driven car?
My car is my commuter and gets driven about 60-70 miles daily, I am not looking for any compromises in drivability or comfort. Taking out any variables such as labor, and cost, what is the current preferred method to adding reliable power via a pulley?
I guess really I'm trying to understand if there are benefits to a SC pulley VS a crank pulley at this point. I could go either way but don't fully understand the pros and cons of either setup. Thanks in advance for any help/advice.
Throw an 83mm upper pulley on there with box tune (tune of your choice, they're all tried and work). It's the perfect daily driver setup with zero compromises and good bit of power/TQ bump.
For what it's worth, I daily drive my car and rarely drive it like a granny.
I've done 70k miles on a 72mm upper and stock lower and it's fine... except it eats oil 1qt every 1k miles.
It was 2% bigger and a even bit lighter than the stock rubber unit.
crank will give you less belt slip as you increase the surface contact area of the belt. A smaller upper course is less to grip so more belt slip. BWK will help but likely to still get some. I still run a BWK with my 195 to ensure still lower chance.
Is there a noticeable difference between stock and an 83mm and tune?
