100 oct racing fuel
Old Feb 19, 2005 | 01:04 PM
leadfoot's Avatar
100 oct racing fuel
Hey guys found a unocal76 gas station that sells 100oct. racing fuel.Can you run this fuel in our 55's.Would it be beneficial or would it **** up the engine.Inputs appreciated.
Old Feb 19, 2005 | 02:49 PM
draggingcents2's Avatar
2005 E55
It will help some and it will hurt hurt just help. What are the cross streets and town of the 76 station???
Old Feb 19, 2005 | 03:00 PM
leadfoot's Avatar
You made no sense.Do you reread what you write?
Old Feb 19, 2005 | 03:19 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Honestly dude, from all the research I have done....it's only good for a few HP and 476/490 (whichever you believe 55's have) to 480/495 really isn't noticeable.
Using info from Hot Rod test of high octane fuels on the dyno.....actually it was racing gas so you might not even get that much HP.
Just my humble....some will differ and that's okay.
http://www.hotrod.com/techarticles/72498/
Old Feb 19, 2005 | 06:27 PM
DerekFSU's Avatar
I've run both 100 and 105 octane. Heard it can damage the oxygen sensor. Never saw any gains with it so haven't done it since.
Old Feb 19, 2005 | 10:13 PM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
If the 100 octane was unleaded it will not harm your 02 sensors. Only leaded racing fuel will harm your 02 sensors.
Old Feb 19, 2005 | 10:34 PM
vrus's Avatar
2003 E55 AMG
If you want to increase the octane rating in your fuel and create better combustion, just drop some pure methanol into your gas tank.
I am not sure what the proper ratio of fuel/methanol should be, but it is cheaper and should be easier to find than race fuel.
Old Feb 20, 2005 | 02:05 AM
Evolution Marine's Avatar
2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Talking More HP
leadfoot - Anything over 94 Octane Unleaded Fuel the ECU can not advance the timing enough to take advantage of the added octane, so 100 Octane fuel is not necessary with OEM programming in the ECU. Reprogram the ECU for the 100 octane race fuel and more boost and you will be able to take adavntage of the added octane, however you will need switchable ECU programing ability to be able to run pump gas when you are not running race fuel. You will also need the ability to switch cleanly between the fuels which requires an oxcilliary fuel tank for the race fuel and some solenoid valves, fuel lines, and some electrical work. - Bob
Old Feb 20, 2005 | 03:38 AM
Marcus Frost's Avatar
Real Cars
Derek,
Unleaded 100 or 104 octane cannot damage the oxygen sensor. Leaded can.
-m
Old Feb 20, 2005 | 10:10 AM
DerekFSU's Avatar
Originally Posted by Marcus Frost
Derek,
-m
Cool. Never got any better times anyway.
Old Feb 20, 2005 | 10:12 AM
Dr Chill's Avatar
Porcelain Bus
I ran tanks of 93 octane and 100 octane back to back at Sebring and couldn't tell the difference. Save your money.
