Old Jun 24, 2015, 08:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels and Tires
Print Wikipost
Slight creak/squeak when turning at slow speed
Old Jan 9, 2011 | 08:43 PM
E-Ridium 63's Avatar
W212 E63
just wanted to see if there are any guys out there that are experiencing a slight squeak or creak when turning the steering wheel especially at the end of rotation of the wheel. I hear it when I'm turning at a stop sign or in the garage when i'm cranking the wheel over a couple of times. Its more pronounced at the ends of the turn. Sounds like a a squeak or maybe a slight buzz. Anyone have this or know what it may be?
Old Jan 10, 2011 | 03:05 AM
Racing Dad's Avatar
e63 2010 W212
nope... sorry. ill pay extra attention, but i doubt ill notice anything if i haven't already.
Old Jan 10, 2011 | 10:40 AM
sluser123's Avatar
2010 W212 E63
yes - same issue here. It seems more pronounced in cold weather (less than freezing). I too will try to isolate it.
Old Jan 10, 2011 | 07:11 PM
AlbertM's Avatar
E63 AMG 2010, Black, Pano, P2
I have the same issue and it seems to be coming from the front struts on both sides. The dealer confirmed this and will be replacing both front struts sometime this week.
Old Jan 10, 2011 | 08:39 PM
W212 E63
Thanks. Let me know how it goes and if it works, let us know what specific work was done. Its not a real big deal right now but I can see it developing to a point later where it will really bug me.
Thanks!
Old Jan 10, 2011 | 09:38 PM
AlbertM's Avatar
Thanks!
Will do. I have an appointment this Friday.
Old Jan 11, 2011 | 10:35 AM
gstatus929's Avatar
2014 E63 S-AMG
Hey, i just went in for the same thing because my noise got louder and louder.
My cars at the shop now, they are replacing both front struts.
Old Jan 11, 2011 | 01:39 PM
W212 E63
Thanks GT. How long is the work supposed to take? Which dealer do you work with?
Old Jan 11, 2011 | 01:46 PM
W212 E63
Guys - Also if you can tell me how they determined it was the struts it would be great. Is this a known issue where there is an internal service bulletin or did they just test drive it and figured it was that?
Mine isn't so bad right now so I can see going in there and the dealer just dismissing the problem b/c they'll "won't hear it". But you guys are probably like me and can hear any weird or unusual noise no matter how faint it is.
Thanks again.
Old Jan 11, 2011 | 02:32 PM
AlbertM's Avatar
Thanks again.
It seems like a known problem. They knew within 15min that it was a problem with front struts.
Old Jan 11, 2011 | 05:57 PM
gstatus929's Avatar
2014 E63 S-AMG
iM WORKING WITH BENZEL BUSCH IN NEW JERSEY.
This is my 4th time in service, the first thought it was just a ball joint but replacing it did not resolve the problem.
Then my alighment was off and they had to remove my whole front end to do alignment.
finaly they determined its the struts, took 1 month to get parts in stock.
now waiting on status, so far 2 days and still not done
Old Jan 11, 2011 | 06:26 PM
W212 E63
Yikes! Here i was thinking over the weekend that all they would have to do is go lube some joints or something to fix it. Thanks for your help guys. If you don't mind, let me know the name of your service advisor. I'm at Ray Catena. If they're hesitant, I'll have them call your guy at Benzl or your guy in LI, Albert.
Thanks, again. Cheers
Old Jan 12, 2011 | 11:05 AM
gstatus929's Avatar
2014 E63 S-AMG
service advisor in benzel was frank armando,,,,,,,,,,,,,, also catena has a good service department too. are you in edison or union catena? let me know what they say
Old Jan 12, 2011 | 11:08 AM
W212 E63
I'm at Union, but i think the edison one has the bigger service dept. Probably won't go in for a few weeks but I'll keep you all posted on what they say.
Old Jan 12, 2011 | 11:15 AM
Vic55's Avatar
Administrator
I freaking hate this forum- I read this and thought "I aint got no noises" and then I was driving in a parking structure at low speed and rolled down the window; small clicks... WTF?
Old Jan 12, 2011 | 11:55 AM
W212 E63
i know; ignorance can be bliss.
Fortunately, and unfortunately, I have the ears of a bat when it comes to squeaks and rattles...(coincidentally, they don't pick up on the wife's voice quite as well). I'm thinking this is the tip of the iceberg. The three of us are in the Northeast and I'm sure the cold weather up here helped aggravate the problem. At least we're catching it early, if that's any consolation. Good luck guys.
Old Jan 12, 2011 | 09:10 PM
AlbertM's Avatar
I am going to Rallye Motors, Roslyn NY this Friday to fix this problem. All the parts (struts) are in and ready to go. Will report Friday what they did and if it fixes the problem.
Old Jan 13, 2011 | 10:26 AM
gstatus929's Avatar
2014 E63 S-AMG
FYI alignment on our cars requires 7 hours of labor: Removal of front bumper, removal of intercooler / radiator. removal of several joints.
Old Jan 13, 2011 | 10:52 AM
W212 E63
That's freaking crazy! When this thing goes out of warranty, we're screwed! Anyone know what the extended warranty costs? I heard it was something like 5 grand a year!
Old Jan 13, 2011 | 12:23 PM
Vic55's Avatar
Administrator
Mine didnt take this long nor did they have to do this process... I watched them do it. It was around 2 hours.
The set the toe and caster- no camber adjustment on these cars unless you install the bolts.
Old Jan 13, 2011 | 03:04 PM
gstatus929's Avatar
2014 E63 S-AMG
VIC DID THEY REMOVE YOUR FRONT BUMPER?
Old Jan 13, 2011 | 03:09 PM
gstatus929's Avatar
2014 E63 S-AMG
GUYS BAD NEWS...............
I WAITED 1 MONTH FOR STRUTS TO COME IN , JUST GOT A CALL FROM THE DEALER AND THEY SAID THE STRUTS ARE IN BUT THE NOISE HAS NOT GONE AWAY!!!!!!!!!!!!!!!!!!!!!!
WHAT DO I DO? I GET A CRACK/GROWL/SQUEAK WHEN MY WHEEL IS TURNED ALL THE WAY TO THE LEFT OR RIGHT?????????????
Old Jan 13, 2011 | 03:16 PM
AlbertM's Avatar
Wow, I am really concerned now. What did the dealer say? They are supposed to tell you what to do next. My car is going in tomorrow. Looks like it will be waste of time.
Old Jan 13, 2011 | 04:03 PM
W212 E63
Shiznit!!! If they're underneath the car and turning the wheel, can't they isolate the sound? Sorry, I'm lost on what the next steps would be besides letting them do more tests. I'll take my car in soon to the dealer and see what they say.
Old Jan 13, 2011 | 04:04 PM
Vic55's Avatar
Administrator
No, all the adjustments were from underneath.
