Wheel offset of w212 e63 and w218 cls63
Can anyone comment on maximum wheel spec possible on both cars without rolling the fender? In my case, rear sticks out so bad that it won't be solved with alignment/fender rolling anyway.
Posted from Mbworld.org App for Android
I think your problem comes from the difference between the wheel specs on the CLS63 compared to the E63.
I know the 19" forged wheels look identical on the 2012 CLS63 and E63 but I believe the rear wheel size and offset are different. The E63 rear wheel is 19x9.5 (offset 52) while the new CLS63 rear wheels is 19x10 (offset 47).
Since this issue is for both cars, I thought I'd hear from CLS guys as well.
I didn't know those 19" forged wheels have different specs, since they look virtually identical.
Based on the spec above, CLS can accommodate at least 1cm (et10) or half an inch bigger than E. I guess I have to pay for my own wrong judgement, damnit...
20x9-29mm
20x10-39mm and the rears sit a bit past the fender but dont rub. The tire size and brand will make a huge difference also. I would not go any lower than a 39mm on a 10 inch wheels.
I am running 295/25/20 Hankook
Will they fit a 2014-2016 E 63 AMG?
Thanks!
