E63 AMG wagon 2015 - weird chirping noise
Old Mar 23, 2015 | 11:25 PM
durask's Avatar
2016 E63 AMG S, 2018 C300 cabrio
Just got this a few days ago and there seems to be a chirping noise when driving at speeds over 40-45. Sounds almost like crickets.
Best to listen with bass turned way down since it drowns out the high pitched noise I am talking about.
I found it is easiest to listen to on a phone - in headphones on my PC I can't hear the noise at all but on no-bass phone speaker the chirp is immediately obvious.
Old Mar 24, 2015 | 08:20 AM
PeterUbers's Avatar
I hear it
Wonder if it's the front grill that had a tsb for gap in the grill causing high pitched noise
Hope you get it fixed
Old Mar 24, 2015 | 08:57 AM
cwcm's Avatar
E63
Chirp
Can you hear it more distinctly with the windows up or down?
Does hitting bumps, lightly pressing the gas / brakes, seat/steering wheel position or air con settings make any diff?
Old Mar 24, 2015 | 09:20 AM
sc98's Avatar
2015 E63S sedan
+1
I haven't noticed the chirping demonstrated in the video, though i do hear a wind buffeting noise when driving at speeds with my sun roof open (sounds like a playing card stuck in the spokes of a bicycle wheel). It is not apparent to me when the roof is closed.
Old Mar 24, 2015 | 04:41 PM
MPE430's Avatar
2016 E63S AMG, 2012 ML350
I have the same noise on my 2014 E63 Sedan. First thought it was a gap in the window seal causing a whistling noise from the wind but it doesn't happen all the time nor above certain speeds. I am having my dealership install something pertaining to the hood/grill tomorrow and will let you know if that solves the issue. Very annoying though.
Old Mar 24, 2015 | 06:31 PM
PeterUbers's Avatar
Yeah they're gonna add cheap foam in the gap ... High tech stuff ... Good luck
Old Mar 24, 2015 | 07:29 PM
MPE430's Avatar
Actually dealer had to order some supplemental part for the job-I'll find out tomorrow what exactly it is. However I'd take foam or any type of caulk to stop that damn noise as I'm sure Durask can attest.
Gonna roll the dice and have the Winter tires switched out tomorrow as well. Hopefully no more snow in Chicago this year.
Old Mar 24, 2015 | 08:50 PM
PeterUbers's Avatar
Lol... Sorry, "glue" not foam... Oh well hope it gets fixed for ya
https://mbworld.org/forums/e-class-w...ling-ride.html
Enjoy the read ... Been discussed before
https://mbworld.org/forums/e-class-w...ml#post6149979
LI88.20-P-058905 Apr14 – e63 wind noises area of bumper/engine hood between 45-80 mph, gap between trim and bumper greater than specified dimension remove front bumper and glue chrome frame to ensure stability.
I'm in Chicago burbs too and was tooling around causing trouble in the e63S before THE SNOWSTORM LOL!!??? Unreal our weather
Old Mar 24, 2015 | 10:28 PM
durask's Avatar
Thank you all for replies. Will call the service advisor tomorrow.
Old Apr 4, 2015 | 11:16 PM
durask's Avatar
All fixed, once again thanks to everyone!
Old Apr 5, 2015 | 10:14 AM
UNC Sooner's Avatar
2015 E63 S
sc98, did you ever determine the source of your noise? I also drive a 2015 E63s. Have around 1950 miles. Just took it to the dealership to have the rear axle oil changed. I mentioned hearing a sound like like the one you describe. In fact, I also described it as a playing card in the spokes of a bike. My sunroof was not open when I heard the noise. One technician heard the noise but could not find the source. They kept the car over night. Next day, they claimed they could not hear anything and said I was hearing rocks hit the underside of the car. They could not find anything mechanically wrong.
Old Apr 5, 2015 | 10:31 AM
faz492's Avatar
e63 amg w212 6.3
could be your drive belt.
Old Apr 5, 2015 | 11:03 AM
mb_nyc's Avatar
2016 e63 wagon
what was the issue ultimately?
Old Apr 5, 2015 | 02:58 PM
sc98's Avatar
2015 E63S sedan
I just took mine in for the rear diff oil service too a few days ago. The noise i haven't really paid it much attn to lately. I've only ever heard it when driving with the sunroof open and i just attribute it to a wind buffeting effect. I don't notice it with everything closed or with just the windows open. With the sunroof open it seems to occur only when driving at a decent speed but it's now either less than it was, or otherwise i've gotten used to it where I don't even notice it. It never bothered me more than a minor annoyance, and I didn't ask the dealer about it either.
Old Sep 27, 2015 | 12:49 PM
oliver_nyc's Avatar
G63
hi - i'm having exact same noise on my two week old e63s wagon. how did they ultimately resolve it? was it: LI88.20-P-058905 Apr14 – e63 wind noises area of bumper/engine hood between 45-80 mph, gap between trim and bumper greater than specified dimension remove front bumper and glue chrome frame to ensure stability.
thanks for any help - am going to dealer next week and this will help me guide them.
Old Oct 17, 2017 | 10:37 AM
goodmaj's Avatar
2020 GLC63
I too am experiencing the chirping/whistling noise. For me it presents around 60-70 MPH and when there isn't a car in front on me. I went to the dealer this morning to get the TSB fix referenced elsewhere but was told that after the fix the gap between the grille and the front would actually be larger to the point where one might think the grille wasn't seated properly. They said they did it on a sedan a couple of months ago and the first thing the owner said was "is the grille not pushed in all the way?"
For anyone who's had the fix, what are you seeing re: the gap? I'd rather go with the "official" fix, but for now, I decided to punt and instead, when I get my clear bra in a few weeks, have that go over the existing seam to see if that resolves the issue. I'm also going to put some painters tape over the seam and see if that solves the problem and if yes, then the wrap should solve the problem. Thanks!
Old Oct 17, 2017 | 10:59 AM
durask's Avatar
Sorry, my brand new car got rear ended big time soon after that and I got rid of it so I don't really remember, it was over 2 years ago...
Old Oct 17, 2017 | 11:30 AM
PeterUbers's Avatar
got the fix years ago and the gap is fine
go to a different dealer
Old Oct 17, 2017 | 07:22 PM
Chappy's Avatar
AMG
Get it fixed. No issues since!
Old Oct 17, 2017 | 10:23 PM
goodmaj's Avatar
2020 GLC63
OK, ok. Question - I've read some things that say the fix is the foam strip while others have said glue the grille. Which fix did you guys get? Quick picture?
