Upgrade spark plugs for tune Mercedes
Old May 14, 2016 | 11:17 PM
  #151
mjd222's Avatar
e63
Now my engine is smoking like hell
  #152
kponti's Avatar
E63
wrong person
Old May 14, 2016 | 11:20 PM
  #153
mjd222's Avatar
e63
Now my car smoke like Hill
Old May 14, 2016 | 11:36 PM
  #154
Fairbird's Avatar
C300
So the turbo is damaged not the motor ?
Old May 15, 2016 | 11:14 AM
  #155
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
yes its fudged to the bones
Old May 15, 2016 | 04:42 PM
  #156
n0psled's Avatar
2014 E63 AMG S
Originally Posted by mjd222
hi
i used Brisk plugs on my engine
it is a ****ed up plugs
it ****ed up my engine
and when i send them and email them they didn't answer me mail
guys becarfull from using this plugs
Interesting... Which plug is that? (Brisk plug number?)
Old May 15, 2016 | 04:46 PM
  #157
Geno51's Avatar
E63 amg s
I second the brisk plugs avoid at all costs. I used to own a 2014 ecoboost pickup and there were plenty of cases where brisk plugs broke apart after just a few hundred miles. Avoid at all costs.
Research Ecoboost F150 brisk plug failures. They are junk
Old May 15, 2016 | 06:20 PM
  #158
mjd222's Avatar
e63
I don't know the number but I give them my car specs and they send me the plugs
Old May 15, 2016 | 06:28 PM
  #159
mjd222's Avatar
e63
One turbo cost more than 3K$
  #160
KLR CLS's Avatar
CLS63 PP
Hate to tell you but detonation caused your trouble not the plug. You have physical damage to the plug. You haven't even pulled the head off yet so not sure why you think the problem is your plug. I bet a chunk of ring land is missing too.
Old May 15, 2016 | 06:31 PM
  #161
mjd222's Avatar
e63
I remove the hose that attached the turbo from the compressor side to the intercooler
And when I start the car it Pors oil from it
I do compression test it passes No problem
Old May 15, 2016 | 06:32 PM
  #162
Geno51's Avatar
E63 amg s
I have seen no less the 5 F150s have brisk plugs fail on 100% stock trucks . It was not detonating brisk plugs should be avoided
Old May 15, 2016 | 06:34 PM
  #163
mjd222's Avatar
e63
When the blood was broke so only the smoke coming from the engine bay when I open the hood and she was literally covered in oil I checked the block there's no crack and I found tons of oil inside the and I found tons of oil inside the Ephrata air box
Old May 16, 2016 | 10:35 PM
  #164
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
I was told that if you have the 2012/2013 E63 models, you should upgrade plugs if doing a tune. 2014+ E63 came with a colder plug and now if you were to buy a plug for a 2012/2013 that you would get the 2014+ plug. I called the dealer and they confirmed it, so whose using these updated plugs with a tune and is fine?
Old May 17, 2016 | 12:47 AM
  #165
mjd222's Avatar
e63
I just came from delar today 2012 and 2014 same part number
Old May 17, 2016 | 01:00 AM
  #166
yes, now they are but originally there weren't. Originally the 2012/2013 had hotter plugs which caused the misfire, so they changed the part # and gave the 2012/2013 the same plugs as the 2014+. If you ask the dealer, they'll tell you the 2012/2013 got new part #s due to the change
Old May 17, 2016 | 01:38 AM
  #167
mjd222's Avatar
e63
0041596403
They Gived me this number
Old May 17, 2016 | 10:01 AM
  #168
gaspam's Avatar
that would explain why tuners recommend current stock plugs with them being one step colder than the original verison of stock plugs
Old May 17, 2016 | 10:03 AM
  #169
gaspam's Avatar
i have them and have not had a problem with misfires for about 10K miles tuned so far
Old May 17, 2016 | 04:30 PM
  #170
johnnyblaze's Avatar
CLS63S
I have the revised plugs (2014+) also. 3k miles tuned, no issues.
Old May 17, 2016 | 11:12 PM
  #171
yes, got my updated plugs today as well as a SPEEDRIVEN tune, my 2012 E63 had the original plugs and they were all white which clearly means they were getting hot. They definitely would've exploded if I were to leave them on with the tune. The stock updated plugs are the way to go IMO. Forget everything else
Old Aug 10, 2016 | 07:23 PM
  #172
Stubbyfoil's Avatar
From: Mercedes Benz of Catonsville, Maryland AMG Performance Center, Renntech Dealer
2005 E55 AMG - Weistec Supercharged, 1994 Nissan Skyline GTST (650whp), 2012 E350 4-Matic (Wifeys)
I can confirm that MB has changed/updated spark plugs, and I've also attended the technical engines Class for the M276/M278 direct injection engines. One thing I remembered is that the spark plugs/electrodes were indexed, meaning that the threads of the plugs and the electrodes were "timed" the same on every plug, and all of the threads on the cylinder heads start at the same place, so when the spark plugs are properly torqued, the electrodes wind up in the same position inside of the combustion chamber in every cylinder. I highly recommend running factory plugs on any sort of tuned engine south of ~850hp. My dealership deals directly with Renntech, and Rennntech suggests the use of OEM Mercedes Benz plugs, saying they need replacement every 10k-15k miles. In my vehicle with their "intermediate" tune, I run the gaps slightly tighter than factory, around .024. Also noteworthy, we have been replacing cylinder heads for burnt valve seats, so while replacing a spark plug is probably one of the quickest and most cost effective way to "troubleshoot" a misfire, spark plugs aren't always the cause. There's some great information in this thread, but I figured I'd put my .02 cents in for some food for thought.
Old Mar 2, 2017 | 07:38 PM
  #173
Geno51's Avatar
E63 amg s
Delete
Old Mar 2, 2017 | 08:14 PM
  #174
Geno51's Avatar
E63 amg s
Delete
Old Mar 4, 2017 | 09:11 AM
  #175
s3w2s1's Avatar
Wagon
AMS just recommended a tighter gap because of misfires. I have yet to put them in. OEM plugs
