Alternator or battery issue?
Now tonight, I put a volt meter on the main battery when the car was off and had been sitting. Around 12.3 I believe. Cranked the car, on startup it was 14.8. After a minute or so, it was 11.8
pulled in my driveway and now the car won't start... Any ideas?
#are61
novae500
Drives: W211
No luck got the car up and running and still have the red battery light. Front aux battery not charging, sitting at 12.6v while rear goes to 14.0...so probably the aux relay cable is bad. Taking it to get diagnosed at my indy shop Benz Elite.
Ok here's what just happened. Once the video uploads I'll post. The alternator wasn't charging to save my life for a few miles. Got to the point where the battery was at 9.7 or so. It got so bad the car stalled out in a turn for a brief moment, and when I got in the gas it fired back up, with 102Amps and 14.7v. I got cut off by someone calling me in the video, when the car came back to it was at that high amp
Tomorrow, I'm going to put a multimeter on the Aux battery. I got under the dash and got it out where it can be tested. If that is a no go, I'm debating whether I should go for the voltage regulator or main battery.
Main battery seems suspect considering this. When I turn the car off, I'm reading 12.7 or so. After a mere 5-10 minutes, it drops to 11.8-12.2. So it seems like the main battery is draining down when the car is off, pretty rapidly actually. But the deal with the alternator throwing anywhere from -80A to 105A beats me. I feel as if either the voltage regulator has it thrown off, or the battery has a bad cell or something of that sort and is throwing everything off. OR the Aux battery is. Aux battery is 6 or 7 years old, never been replaced. Man this is a pain in the ***. I refuse to take it to a dealer though. I don't have the time, don't have the money to blow there, and would like to learn about some of the issues by fixing it myself
Here's a theory I had. Maybe I'm wrong
So the car doesn't start acting up unless it's at full operating temp and has been for a while. Maybe the brushes on the voltage regulator are worn out, and when they get hot they just don't make a good connection anymore?
