Post your wheel/tire setup with pictures and information...
Old May 17, 2019 | 12:26 AM
  #76
727E63AMG's Avatar
2014 E63 S, 2017 GLE 43, 2020 Cadilac Escalade, 2019 Lamborghini Performante
Rohana 20"
Old May 18, 2019 | 06:40 PM
  #77
Fandan's Avatar
2014 Mercedes e63 s-amg
hi. i see you have 20x10 with et 35. any issues with rubbing abd what size tires did you go with?? thank you
Old Jun 22, 2019 | 02:45 AM
  #78
6speeddave's Avatar
MB
19" HRE P43SC + Michelin Pilot Sport 4S. I actually just listed them for sale here. They are W212 E63S spec. Figured Id also show a few recent shot of them on the car one last time!
Old Jun 22, 2019 | 12:15 PM
  #79
1MavRick's Avatar
CLS 63 and M4
BRUH!!! LOVE the choice in tire sizes. looks so meaty and aggressive. if these were in bronze i'd be tempted to scoop up the set. GLWS!!!
Old Jun 22, 2019 | 01:04 PM
  #80
Ed99's Avatar
E63s AMG
Wheels: Work Wheels Zeast ST1 2pc
Wheel Size: 20x9.5 and 10.5
Tires: Michelin PS4S 255/30 and 285/25
Old Jun 23, 2019 | 05:07 PM
  #81
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
What offsets are these? Is this lowered or stock suspension?
Old Aug 12, 2019 | 10:24 PM
  #82
Josh Morris's Avatar
2008 ML 63 AMG. 2002 slk320
bad ***
Old Aug 12, 2019 | 11:33 PM
  #83
Ed99's Avatar
E63s AMG
20x9.5 31et and 10.5 32et on KW HAS kit
Old Dec 22, 2019 | 03:58 AM
  #84
Kkpm's Avatar
2014 E63
So for the w212 4wd, 20 x 10” with et 35 is fine in the rear?
trying to fit a set of after market wheel made for s class wheels on the E......
Old Dec 22, 2019 | 11:37 AM
  #85
Magno's Avatar
2013 E63 Estate
Yes but you would have to run a 275 tire. A round shoulder 285 ‘might’ work.
Old Dec 22, 2019 | 02:35 PM
  #86
Kkpm's Avatar
2014 E63
Thanks! Anyone has experience with this setup? 20x10 et 35 in the rear and 20x9 et25 front ...... Pics ???
Old Apr 26, 2020 | 02:58 AM
  #87
Kg810's Avatar
2016 E63s Wagon
Could use some thoughts on whether this setup works. I'll be lowering on KW HAS soon.
Front
255/30/20
20x9 et 25
Rear
275/30/20
20x10 et45
I'm thinking of lowering by an inch, but willing to do less if required. Not looking to rub, but I'm wondering if 285/30/20 will work in the rear.
If anyone has this setup I would love to see some pictures.
Old Apr 27, 2020 | 02:59 AM
  #88
SAMzE63s's Avatar
E63s
Front
255/30/20
20x9 et 25
Rear
275/30/20
20x10 et45
you should be fine, specially with 275
you in Edmonton?
Old Apr 27, 2020 | 10:58 AM
  #89
HPMan's Avatar
2014 E63 S
Front
255/30/20
20x9 et 25
Rear
275/30/20
20x10 et45
You'll be fine on the rear. I'm 20x10 ET45 and run 295/25R20 without rubbing. I think you may have some trouble up front though. I'm 20x9 ET38 with 265/30R20 and am fine fully lowered. However, I tried it with a 5mm spacer (making it ET33) and would rub on compression. Here's a crappy iphone picture of my setup.
Old Apr 27, 2020 | 11:01 AM
  #90
Kg810's Avatar
2016 E63s Wagon
you in Edmonton?
Thanks. I'm in Calgary.
Thanks for the info. Are you on KW HAS as well?
Old Apr 27, 2020 | 11:24 AM
  #91
HPMan's Avatar
2014 E63 S
Yes, KW HAS.
Old May 5, 2020 | 10:28 PM
  #92
_KO_'s Avatar
2015 CLS63, 2020 GLC300 Coupe
Hello All,
Looking for some wheel advice, I see the W212 forum gets a lot more action than the w218.
I don't know much about wheels (never bought a different set before...always stuck with the same rims the car came with) but I found a good deal on some rims for my 2015 CLS63.
I've always wanted the black OEM 9 Y Spoke wheels. (I have the gray 10 spoke)
I found an OEM set off of an AMG GT
Would these fit without any issues?
Fronts: 19x9 ET61
Rears: 20x11 ET68
My stock rims are:
Fronts: 19x9 ET37
Rears: 19x10 ET47
I did a bit of reading and I think I would need longer lugnuts, would I also need spacers all around? I would also need 305 or 315 tires for the rear. any potential issues anyone can see?
Planning to keep my original wheels as a winter setup.
Thanks in advance
Old May 6, 2020 | 12:10 AM
  #93
Rehabguy's Avatar
E63S
[QUOTE=_KO_;8048287]Hello All,
Fronts: 19x9 ET61
Rears: 20x11 ET68
My stock rims are:
Fronts: 19x9 ET37
Rears: 19x10 ET47
[/QOTE]
Sticking with a 255/30/19 you'd be able to run the F wheel w/ a 25mm spacer. Definitely longer wheel studs.
A 25mm spacer at the back, that'll leave you with a +43 offset. With a 305/25/20 you'd be 15.1mm closer to the suspension and poke out 23.1mm.
I do know the W218 can fit a slightly more aggressive set up that the W212. I also do recall seeing a pic of a white CLS63 sporting 315's at the rear.
It should work, but, I personally wouldn't wanna run 25mm spacers.
Old May 6, 2020 | 09:40 PM
  #94
_KO_'s Avatar
Hi @Rehabguy
Thanks for the response!
Does Poke out mean the wheel will hang out 23.1mm outside of the fender?
Lets say instead of a 25mm spacer I go with a 15mm or 20 mm spacer; would there be enough wiggle room where I don't rub the suspension?
Any reason why you wouldn't run a 25mm spacer, could it cause any issues in drivability?
Problem is I am buying them off some guy whos gonna send them to me via a friend of a friend who drives back n forth 4.5hrs from where the wheels are located. So I would be stuck with them if they didn't work out.
Thanks again!
Old May 7, 2020 | 12:08 AM
  #95
Rehabguy's Avatar
E63S
Originally Posted by _KO_
Hi @Rehabguy
Thanks again!
NP.
By poke out I meant the wheel will "shift" or "stick out" twd the fender.
For the front, I have seen members post set ups where the ET was slightly higher than stock (ie, a +40 but don't quote me on this, said offset might have been on a 8.5" wide wheel) With an offset of +35 at the front it is already pretty close to the strut.
A 11" wide wheel and a 305-315 tire will really be maxing out the room available even for a CLS. I seriously do not THINK you have 10-5mm to play with on either end (fender or suspension).
The reason why I said that I wouldn't run such a large spacer is somewhat debated. There are people who say that spacers will harm/shorten the life of wheel bearings. Also, spacers may some times cause vibrations. Maybe they'd also add unsprung weight?
How good a deal are these wheels? The good thing about high offset is that you can always throw wheel spacers at the wheels to make them fit. However, I dunno if it'd be such a great idea to throw ginormous spacers on your AMG.
Old May 7, 2020 | 02:38 AM
  #96
Rehabguy's Avatar
E63S
@_KO_
Seems like the W218 is way more capable wheel size wise than the w212.
Pls go over this thread posted over at the w218 amg forum: https://mbworld.org/forums/w218/4688...p-club-20.html
GL w/ the wheels.
Old May 11, 2020 | 07:15 PM
  #97
Ncbimma's Avatar
E63S
5X112 20X9.0 +35
5X112 20X10.5 +45
PS4S
Old May 11, 2020 | 09:25 PM
  #98
Mtn Ryan's Avatar
M3
Originally Posted by Ncbimma
5X112 20X9.0 +35
5X112 20X10.5 +45
PS4S
Any issues with that set up? I'm looking at a slightly less aggressive set of 19's and am very curious. Thanks!
Old May 11, 2020 | 09:29 PM
  #99
Ncbimma's Avatar
E63S
None at all. Full lock and major hwy bridge dips at speed see no rubbing. I wanted the most concave look without rubbing.
I'm stock suspension, fyi
Old May 11, 2020 | 10:50 PM
  #100
Rehabguy's Avatar
E63S
What sizes tires are you running?
Thanks.
