Plasti dipped my E63-AMG S
If you're interested in doing it yourself, here is the best way:
Using painters tape - tape a rectangle around the badges giving yourself a few extra inches of space around the badges. I would also tape off around it a good area because to avoid having to rub off small amounts of overspray.
Clean the badges off so there isn't any dirty on them or anything.
Start coating. I'm a fan of going light and just applying 4-5-6+ coats of plastidip. This way you don't risk any drips. Just a smooth application. At the end you want it to be thick enough so that when you peal it doesn't tear apart into a bunch of little pieces.
Remove tape and peal the excess dip carefully around the badges. Because the badges are raised, when you peal around them the plastidip will stay on the badge and peal off your paint. You won't really have to worry about separating the dip on the car from the dip on the badges.
And done. It's a fairly simple process and the nice thing about plastidip is if you mess up it comes right off. I would start on the rear badges (or something easy) though before diving into things like your grill or whatever.
Lastly - I would do it in a garage/closed space that doesn't get a breeze. This will minimize overspray.
It is a process, and patience is a large part of it, but it is a simple process.
My best advice would be go buy a can and use it on something else. Get familiar with the stuff to get a little confident and then off to the races once you realize how easy it is.
YouTube videos really helped me
Evan
