MY first CEL @42k
2014 E63s 1993 mazda rx7 on Boost
MY first CEL @42k
2014 63s 42k BMC filters stock ECU and spark plugs.
P013E sensor delayed rich to lean B1 S2.
Is it safe to say that this is the second sensor on the passenger side (B1)
Does anyone know brand of the OE sensor. I am thinking i will replace with Denso, i have always seen result with them on turbo cars, Supra RX7 300Z. Even my single wire o2 on the GN is a denso. Never good luck with the bosch and @40k I am going to guess our OE sensor is a Bosch.
Now the light clear on it own after a few cycle and only seem to pop on a when temps are below 25 deg. car drives fine no misfire.
I am also thinking of a AMS tune coming spring and should I go with stock plugs or does the AMS Tune run better with a colder plug...
Thank You all for your replies..
Sunil...
Sunil...
E63 SL55 996TT C5Z06
Sunil...
Sunil...
Thank You..the the positive on AMS
Once I saw Peter with AMS I know where I was going. I was going with EC because I visit Toronto Canada about 3-4 times a year and they are about 30 minutes from where I go.
There is a shop in NYC that can do the tune installation but I am not sure if they can do a dyno clean up.. I will ask.
Received 2,076 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Still loving this ams tune
will be doing this monthly now!! Why are you on the stock ecu??
I referreded you knuckleheads to AMS and now all of you are referring. Lol. Not meaning anything negative here. Just having some fun with you.
Cheers
