W212 E63 M157 - Oil drain plug location
Old Mar 7, 2019 | 09:44 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
W212 E63 4matic M157 - Oil drain plug location
MB recommends - Engine Oil/Filter change every 10k miles/15k kilometers or every 1 year whichever comes first.
Oil filter part # 278-180-00-09
Mercedes recommends 229.5 approved oils “Viscosity 0w40 or 5w40”, couple of them are Mobil 1 0w40 and Liqui Moly 5W40 Leichtlauf High Tech.
Filter element cap - 25nm
Drain plug - m12 20nm, m14 30nm
Filling capacity 8,5 liters. (i start with 7.5 to 8 liters and then add the rest because changing the oil on ramps could alter those variables)
Approx 1 liter between MIN mark and MAX mark on the oil dipstick.
When checking the engine oil level, insert the dipstick and leave it in there for at least 3 to 5 seconds before removing.
M157 oil change kit
https://www.fcpeuro.com/products/mer...81800009-9l-v1
Just a little write up.
Old Mar 8, 2019 | 06:59 PM
Speedy55's Avatar
2004 E55 2008 ML63
No wonder I couldn’t find the plug!
i never removed the splash sheild!
Old Mar 22, 2019 | 04:02 PM
timm206's Avatar
Glad it helped
Old Mar 29, 2019 | 09:55 AM
iceman2002benz's Avatar
2014 Mercedes E63 AMG
nice job and it will help many others who wants to do their own oil changes on these M157 motors.
maybe also add: how many quarts of oils, what weight of oils, oil filter MB number?
Old Mar 29, 2019 | 10:08 AM
timm206's Avatar
Good idea didnt think of that. Will update it.
Old Aug 24, 2019 | 04:37 PM
jcalvinm's Avatar
2014 W212 E63S
Do you have the part number or size of the copper crush washer on the drain plug?
Old Aug 24, 2019 | 05:27 PM
timm206's Avatar
Im using this one, its the same as oem.
https://www.fcpeuro.com/products/bmw...or-32411093596
Old Aug 25, 2019 | 10:25 AM
jcalvinm's Avatar
2014 W212 E63S
Cool, thank you. I saw it was included in the oil change kit they sell but when I select it to order it by itself the site says it doesn't fit my car..... I thought that was weird. Thanks for the info!
Old Aug 25, 2019 | 10:54 AM
timm206's Avatar
No problem
Old Oct 29, 2019 | 06:09 PM
Lumi's Avatar
E63 AMG S
M157 oil change kit
I have read this WIS oil level check sheet and for the M157 if you warm your coolant to 80C and then shut off the engine to check the engine oil level, it will come up VERY low compared to a warm engine at normal operating temp.
I dont recommend checking oil this way, even tho MB WIS document does generally say to do this for multiple engines, it will make your oil read low.
Old Oct 29, 2019 | 06:44 PM
timm206's Avatar
Possibly its wrong but checking the oil 10-15 secs after shutting down the engine simulates the level of oil you have in the pan while driving, give or take. Now if you set your oil level where you let the oil drain down to the pan from the oil channels, you might be on the low side of oil level while operating and running a risk of sucking air lets say on a high G-turn on a track or while launching, that can accelerate wear since m157s dont have the dry sump system. Also not all m157s have oil level sensors if i remember correctly. Either way imo its better to be on the higher side of the limit rather than lower, and of course too much oil wont do good either.
Since oil expands with temp it would make sense to perform the check when oil temp is at least @100f or more. I recently had an oil change done by the dealer and when i check the oil level while the car has been sitting for a while, the level is above the MAX line and near max when i perform the check with the method stated above.
Old Oct 20, 2020 | 02:16 AM
hardyli's Avatar
Lincoln
Great writeup! Really helpful!
Old May 15, 2021 | 03:46 PM
dustinN's Avatar
09E350, 07E63, 13CLS63
This will be the same for w218 CLS63 right? That's what I thought but just wanted to make sure before I start. Thanks.
Old May 15, 2021 | 05:08 PM
SAMzE63s's Avatar
E63s
Should be the same
Old May 28, 2021 | 07:55 PM
vdubpower's Avatar
i drive them all, fast and hard
What's the correct tool or size to remove the cap off oil filter. Thx
Old May 28, 2021 | 08:14 PM
billvp218's Avatar
m157 SL63
27mm socket
Old May 28, 2021 | 09:02 PM
vdubpower's Avatar
Will buy
Old Jan 22, 2022 | 07:10 PM
Strash Petrov's Avatar
R230 SL65 $ W212 E350
M157 oil change kit
Does the oil level sensor is labeled as the M12 drain plug?
Old Jan 23, 2022 | 08:40 AM
kenneyd's Avatar
poop
