Getting multiple cylinder misfires.
Old Mar 8, 2020 | 05:00 PM
Cardinal_E63S's Avatar
2014 E63 AMGS
I've been getting check engine lights every once in a while when I'm driving a bit hard, I could just turn the car off then back on and it would be gone. Then yesterday I got one and it wouldn't go away without disconnecting the battery and it was multiple misfires on cylinders 5,6&8. Is there something that could be causing that? I have a eurotune on the car and that's it. Thank you very much in advance.
Old Mar 8, 2020 | 07:31 PM
PeterUbers's Avatar
How about some details to your story?
are you tuned?
how many miles?
did you have the car new or used?
what type of gas?
Old Mar 8, 2020 | 07:33 PM
2014 E63 AMGS
Yes I have the eurocharged tune, 58k miles, bought it used and I'm using 91 octane mobile gas.
Old Mar 8, 2020 | 08:29 PM
PeterUbers's Avatar
simple answer is fill with higher octane fuel
Can you fill with some 91 and 100+ octane?
Old Mar 8, 2020 | 08:30 PM
PeterUbers's Avatar
Could be ... after fuel is ruled out: plugs and coils but this is very similar to an issue me and others have had with bad gas and tunes on the m157 platform
have the plugs or coils ever been replaced? Tighter gap on new plugs could help but I have anecdotal evidence that it doesn't matter
what tune from EC are you running? How aggressive the tune is matters.....
Old Mar 8, 2020 | 08:31 PM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
OP, when was the last time you changed your plugs?
Old Mar 8, 2020 | 08:33 PM
2014 E63 AMGS
I bought the car at about 45k and haven't changed them. I have the stage 2 tune.I definitely do that but do you think that would cause multiple cylinders to start misfiring at the same time?
Old Mar 8, 2020 | 09:05 PM
There is your problem. They need to be changed every 10k miles when tuned, and you have no idea how old they were when you bought it? Lucky a misfire is your only issue right now.
Old Mar 8, 2020 | 09:09 PM
PeterUbers's Avatar
1,5,8 were my misfires on old plugs
then same cylinder misfires on fresh plugs with 0.022 gap and bad shell gas ... 93 octane
added a bit of 100 octane and misfires went away
credit goes to Jvakos and Vrodman for this discovery
Old Mar 8, 2020 | 09:28 PM
2014 E63 AMGS
Thanks guys I will get them replaced right away then. Can one of you kindly link me to the plugs I should use if you know off hand. Thank you.
Old Mar 8, 2020 | 09:30 PM
PeterUbers's Avatar
Before you do that and spend $800-1200 get a tank of good gas, at least THEN you know the issue. You still need to replace plugs on a tune every 10,000 miles
you want OEM Benz plugs with stock gap OR 0.022
Old Mar 9, 2020 | 04:17 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
10k miles for plugs is a little excessive. 20k in my experience unless upgraded turbos or internal engine mods with a aggressive tune is usually fine.
Old May 22, 2020 | 10:15 AM
jplauric's Avatar
2005 E55, 2016 E63S
I have a similar issue. 50k miles. 2016 E63S. Car is bone stock(to my knowledge) Misfire on 3,5,8. Plugs were replaced as part of CPO program in December 2019 and then again after misfires in March 2020. I just took it to dealer again and they said they had to open a case with corporate to help diagnose issue. I run 91 octane and I only experience issues after very spirited driving. Normal driving is in excess of 90Mph. I have dealer service car after any issue whatsoever. But this time they have had my car for a while. I am now waiting to hear what corporate techs say I should do. Is there some octane boost I should use? I get my gas free at work and I wish to continue to use this benefit.
Old May 22, 2020 | 07:30 PM
ProfessorX's Avatar
2012 E63 Tuned, 2020 Shelby GT350, 1999 S 420
I'm having misfire issues with my AMS tune also. I've stopped using Shell gas, change out all the coils and upgrade to NPK plugs and still having issues. I'm going to call AMS next week and see what options they give me to correct this issue.
Old May 23, 2020 | 08:21 AM
PeterUbers's Avatar
i have AMS tune and had misfires... changed plugs and used a bit of 100octane in the tank of 93 and no issues now
Old May 24, 2020 | 12:28 AM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
I have an AMS Alpha tune on a mostly stock car and had cylinder misfires and limp mode when pushing the car very hard. I just installed new OEM plugs gapped at .022 and so far it hasn’t happened again. The original plugs looked pretty bad at 34k miles and the gaps were around .028. Will be following this thread closely. I still need to install the AMS aux heat exchanger I bought with the tune.
