Reduced IAT's - Pump rewiring
that makes sense, I am going to revert the always-on wiring and see if I notice any difference in feel and on the monitors while driving. If there is no difference with this tune then one less P-code to worry about.
Now I'm not sure what the merits or the detriments are to having the intercooler run after the car is off for 5 to 10 minutes. Maybe it's good to soak up the heat and circulate it, but if the car doesn't have a fan running and it doesn't have any motion, I'm not sure what the absolute benefit is other than unnecessary 5 to 10 minutes of electronics stopping your battery and running electric motors unnecessarily.
Question- to remove or not to remove the foam like (fuel rail cover) spark plug coil covers on each bank? Do they serve a bigger purpose
I've tried to find the relay using a wiring diagram, but without luck.
