anyone using ECE's "Race/Hard" motor mounts?
The engine is rock steady now. Look in my Black Boost thread for a video showing zero movement during a dyno pull.
The idle was raised a smidge to 850 rpm to eliminate any potential vibration issues with the mounts.
The car idles fine.
The mounts are well worth the money. It's a "one and done" type investment. I have gone through 3 OEM sets of engine mounts. I think of all the money spent on hardware and labor lost before I was turned on to these mounts. If you have to replace mounts... go with these over OEM. They are definitely better.
The car idles fine.
Seriously though...what was the point? There is nothing in there that I was asking for, but thanks!
http://ultimatepd.com/mercedes-black...712400118.html
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
http://ultimatepd.com/mercedes-black...712400118.html[/QUOTEp
Shardul do you like these Black Series mounts better than the ECE mounts? Do they last longer?
will these mounts work with the M157 engine?
