E63S -stock - sputtering start? 39k mile
Old Dec 10, 2020 | 11:42 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
My 2015 E63S has 39k miles running all Stock ECU and I just recently started noticing a sputtering at start up which happens about every other start up attempt.
It’s not the battery as the volts are 14.2 and it cranks immediately but is taking an additional 2-3 seconds to sputter then it starts and runs fine. I have zero CELs or codes and dealer said they couldn’t find anything wrong.
I have one year left on my MB extended warranty and hope to get this sorted out before that expires - am wondering if this is injectors or fuel pump what could be causing it?
here is a 10 second video (turn volume up) - would appreciate any thoughts. Thx fellas
Old Dec 11, 2020 | 12:05 AM
Anotherone's Avatar
W463 G550, C292 GLE63s
This is what I found:
https://forums.mbclub.co.uk/threads/...-p0018.246483/
Sounds like your cam chain(s) have stretched.
Normally symptoms are p0016/17/18/19 faults which is the CPS not detecting the correct position of the cam timing chain.
Other linked causes are a failed CPS, oil ingress in the CPS, ECU loom oil ingress.
It’ll throw a code to start with and after a few miles it’ll come back on, normally on start up. Next stage is the car taking longer to start, this gets worse and eventually will throw a code every time.
For all early M157 engines (2011-12) there was an issue that required the cam tensioners and check valves to be installed due to oil circulation issues on start up. As this was never a recall item, then many cars will have never had it done. The downside for these cars is that in time the chain will stretch and cause position issues and in some cases cause the chain to jump a tooth....not good.
It’s a big watch out for any M157 owners whose engines never had the original work done, plus MB should be ashamed of themselves for never making it a recall item, especially as all cars post 2012 had the new tensioners and check valve fitted, they’ve even upgraded the design of the chains and sprockets!!
With the age and Mileage of these cars there will be more needing this work. I know of some that have stretched at circa 30k miles!
Old Dec 11, 2020 | 08:36 AM
Mojo20032004's Avatar
2014 E63S
its not smart running that low on gas. you might be starving the fuel pump, heating it up(fuel keeps it cold) and risk the possibility of frying it
Old Dec 11, 2020 | 06:16 PM
jvakos's Avatar
thanks for the feedback, and I’ve actually had that problem before on an old C 32 that the wife used to drive and put like a quarter tank in it every time she filled it up which affected the fuel pump wiring and got fried Since there was never enough fuel in the tank to insulate that pump and wiring.
I think it might be the crank position sensor As the starting issues happen even when I’ve had a half tank or more of fuel in the car.
I’ll put a full tank in it and schedule a visit to the dealer to have them take a look at it.
Thanks for your help really appreciate it
Old Dec 11, 2020 | 06:18 PM
jvakos's Avatar
Originally Posted by Anotherone
Thanks for the feedback on the timing chain, but I think I’m OKAY there since mines a 2015 which had the upgraded timing chain I believe I’ll have a dealer check that as well. Thanks for your help on this
Will report back once I get the dealer To take a look at it
Old Dec 11, 2020 | 07:27 PM
maxusa's Avatar
2013 E63 P30, 2010 GL550
By sputtering, are you referring to longer engine cranking needed to start? Is this the noise in the video? Or this noise before the cranking begins? Also, in the video, it seems that you turned the actual keyfob in ignition immediately. What are the symptoms when you just turn ignition, no starting yet? Same issue with the Start button and keyfob?
Old Dec 11, 2020 | 09:44 PM
jonii's Avatar
Alpha 9 E63s AMG Biturbo
i think this is due to a faulty cam position sensor.
Old Dec 12, 2020 | 01:15 AM
hardyli's Avatar
Lincoln
That sounds like starting a tractor in winter.. But curious to know what you eventually find out..
Old Dec 12, 2020 | 04:20 PM
jvakos's Avatar
yes that sputtering at start up for 2-3 seconds is what I’m referring to. It always starts up whenever I attempt to start the car but seems every 1 in 4 starts has this sputtering.
Several have suggested it’s the CPS so will get the car to the dealer Monday snd report back on what they find.
really appreciate everyone’s input on this
Old Dec 12, 2020 | 06:28 PM
PeterUbers's Avatar
It may still be a bad battery, you need the battery tested under a load at the dealership.
Old Dec 12, 2020 | 06:44 PM
cotmfk's Avatar
On the shoulder
I had a similar (maybe same) thing - mine was battery. It was the original battery. You can check the date on your battery. I know you said that was already checked and it is has sufficient power, but mine was as well. Best of luck.
Old Dec 13, 2020 | 08:36 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
You may have a bad coil pack and or battery
Old Dec 14, 2020 | 12:31 AM
jvakos's Avatar
Peter thanks for the feedback. I put the battery on a trickle charger the last two days and it’s been starting totally fine right now so maybe it was the battery as you suggested!
Old Dec 14, 2020 | 12:33 AM
jvakos's Avatar
thanks Cotmfk - I put the battery on a trickle charger the last couple days and drove it quite a bit today and every start was just fine. My car is a 2015 and I will check what it says for the battery date, but thanks for the batter suggestion!
Old Mar 11, 2021 | 10:54 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
I am having the same symptom on my 14 ML63 PP. it happens only after my car has reached operating temp and then parked and restarted again after 3-4 hours.
I checked the cam sensors and magnets for oil contamination and they looked okay.
Did you end up resolving this issue?
Old Apr 25, 2022 | 12:13 PM
Awadin63's Avatar
E63 Amg
Im having the same symptoms, battery changed, at first worked then it happened again
Did you find a solution?
Old Apr 25, 2022 | 12:22 PM
jvakos's Avatar
i still have this issue as well... the sputtering at start up. it seems to happen about every 3-4 starts whether its cold start or been driven and restarted. my battery is 4 years old but i keep the car on a battery trickle charger and from what the battery readings show the battery is OK. car drives totally fine just have this intermittent sputtering to deal with at 45k miles now on my 2015.
Old Apr 25, 2022 | 01:48 PM
BCP's Avatar
BCP
2014 E63s
Do you notice it cranks longer before starting? It is hard to hear in the OP's video. Ive noticed lately mine will crank longer before starting in a similar scenario - drive it, gets up to operating them, then it sits for a few hours. Fuel level doesn't matter, main battery is less than a year old.
Old May 12, 2022 | 12:01 AM
jvakos's Avatar
BCP - hey replied to your post on the whatsapp thread too about this, but yes mine takes about 3-4 seconds at times (every 4th or 5th start) to crank and start up. It happens more when the car has been driven and you park/stop then couple hours later start again. This all started happening to me when i did my race fuel tune (all hardware stayed stock) and I thought the tuner left the lights on or something to drain the battery. Battery tests at 12.7 or so when cold and stays at 14+ when car is operating and the dealer said battery is fine.
no clue whats going on but car performs perfectly fine aside from this sputtering start. not sure if the race fuel (100oct) clogs something in the injectors or fuel pump or whats going on but would like to sort this out
Old May 12, 2022 | 02:05 PM
BCP's Avatar
BCP
2014 E63s
Hopefully someone can identify the underlying cause!
Old May 12, 2022 | 10:38 PM
billvp218's Avatar
m157 SL63
Do you have only a race fuel tune? No e85?
Old Nov 12, 2022 | 01:24 AM
jvakos's Avatar
ALL IS FIXED - THE SPUTTERING WAS CAUSED BY OIL SEEPING INTO MY 4 CAM SENSORS AND 4 CAM SOLENOIDS WHICH HAS BEEN MENTIONED ON THIS FORUM.
DONT DELAY - replace your 4 cam sensors (very easy DIY and cheap part from FCP euro for 40 bucks each) and replace your 2 cam solenoids which are easy to replace (the other 2 are behind the turbos and hard to reach)
I have not had one sputtering start since I replaced. The parts mentioned here in my car is running fantastic. No oil in the ecu harness either
here is my very clumsy DIY video on how to replace the 4 sensors
https://youtu.be/v5BgftLCqJA
